Just installed Triax Shifter Gasket!
ForPointSex said:
Please keep us informed if the handle bolts loosen up. I tried to use a rubber spacer between the shifter base and handle, but the bolts came loose every 3 months.
I use thread-lock.
Works great!
As far as the handle-gasket, it is super thin anyway.
Not spongy at all.
Looks like exactly what I used for mine. I went to Home Depot though, bought some of the high temp plumbing rubber gasket material. It came with 2 pieces about 5x5 for less than 2 bucks. I just cut out 2 little squares that look really close to what he has lol. Made 2 holes in it for the bolts. I am worried about the bolts loosening, Ill be checking on them like once a month for a while. I didnt care about the noise, I was trying to get rid of the notchy feeling the shifter had. Stock shifter felt so smooth, but once I went to the Tri Ax I could feel every bump and movement inside the tranny. It helped some with the notchiness, it really helped cut down the heat that would build up after lots of driving.
