Beau from Mental Addiction Motorsports suggested it to me. I am either going to run Nitrous (150 to 200 shot) or put a 6 psi supercharger on (10.8 to 1 compression). I needed a way to get the car set up so it is safe to run, don't want to be too lean.
It is a really neat install, very easy. All you have to do is drill a hole in the exhaust past the header (driver's side). Then you weld the thing that the O2 sensor screws into. You then connect the wires, route them tight along the engine bay fire wall, through the hole, and under the dash. All you need is a ground and power connection.
I mounted mine under my ash tray on the dash. It is pretty cool. I was running really rich (12.5 at idle). It was really easy to tune the carb. I am not old school, so I don't know how to do it by smell and ear.
The cost was $450. It will help out when I do add a power adder.
