  • SN95 4.6L Mustang Tech
Just snapped a wheel stud
  • Thread starter Thread starter 01PonyGT
  • Start date Start date Mar 26, 2004
01PonyGT
304
Willow Grove, PA
Mar 26, 2004
  • Mar 26, 2004
I just snapped a wheel stud off on the driver's side rear. How do I remove the old stud that was sheared off and replace it with a new one? Does the axle shaft have to come out?? If it does have to come out, looks like I'm going to the dealer. I assume it's not adviseable to drive with only four lugs for an extended period of time, but what damage could it do? It's my only ride these days and I know it'll be until Monday or Tuesday before I can get it repaired. I drive 80 miles a day and will put a few hundred miles on it before I can get it repaired.
Thanks,
WES
merc123
420
North GA
Mar 26, 2004
  • Mar 26, 2004
Thanks,
WES
My g/f's POS had a snapped stud. She drove it for about 1000 miles before getting it fixed. I wouldn't recommend it on the stang but they didn't have to remove the axel. I think it's rather simple though. Just don't know how to do it.
w00t
334
Arlington TX
Mar 26, 2004
  • Mar 26, 2004
I would not take a chance on driving it. My 96' snapped one I thought I could make it to the repair shop...Only to see another one break after that, the whole car was shaking. Ended up replacing the entire axle.
C
cracka1
10
  • Mar 26, 2004
it's been a couple years since I broke one on my 98 (we'll see if I member right)
with a punch knock out the old stud. they are held in by the knurl, looks like the splines on an axle or C.V. shaft. you can slide in a new one (buy at NAPA) without taking anything but the wheel off. just bend the backing plate a bit, slide in the new one and pull it in with an open faced wheel nut.
with this being a 20 min. job tops, I'd drive as little as possible before fixing it, good luck
later,
Wes
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
