Just when I have my car running great, the tranny blows! Help.
Notchbackdrew
44
My auto tranny bit the bullit 2 days ago on my way back rom Dallas. I was a hundred miles away from home, driving in Overdrive, and the cars rpm's began to slip. The RPM's were at 2600 and fell instantly to 1100. When Id give the car throttle the rpm's would shoot up but the car wasnt accelerating. Then after a second or two itd catch and repeat the whole process.
I pulled into a gas station to check to make sure everything was fine and I didnt see any noticeable problems. I have an Art Carr Valve body so I stuck the car in first to get goin, the car didnt move. I had to rev the car up to 3k rpm and then like a hammer itd catch, and id leave the parking lot burning rubber. I felt like such a redneck.
Anyway, this problem happened in every gear, ist, 2nd, and drive. 30 miles away from my house Overdrive was completely gone and drive was almost finished. I had to drive the car at 3600 rpm, the rpm's would shoot down and it was like I was driving in neutral, then Id have to sit there and rev the car to 5600 rpm to try and get it to catch again. Once it did catch Id have to accelerate aggresivly to try and keep it in gear. After 3 or 4 seconds of accelerating Id have to do the whole process over again. I had too stop 5 or 6 times to give the car a rest, and after doing so the car felt refreshed, but it would lose its grip after 5 minutes or so of driving and the troubles would continue.
15 miles away from my house it completely stalled, couldnt get it to move regardless of what gear I was in or how long I rested the vehicle. I was stuck at 1:00AM in the middle of a country farm road surrounded by corn stalks. Kinda scary if you ask me.
Regardless I called a tow truck and got home.
My question to you guys is, does this sound like a prob with the torque converter or possibly the clutches within the tranny itself?
Also how difficult is it to replace an auto transmission? I can pick up a used one for 125$ and am willing to swap it in, I just need to know what Im getting myself into. I replaced my daily driver Honda's tranny last year, but its a 5spd. Do you guys feel a shade tree mechanic would have probs swapping an auto in if Ive never done it before?
Thankyou kindly.
Not hard at all to swap out the tranny . The aod is a heavy bastard so I recommend a tranny jack .
Other than that just disconnect speedo cable , kickdown/TV cable , shifter linkage , tranny cooler lines and electrical harness . I'd also recomend draining the pan first or you'll make a mess . remove the inspection plate and unblot the torque converter then unbolt the tranny and slide it back then drop her down .
I just removed my AOD when I did my T-5z swap . I still have it in my garage and your welcome to it , shifted perfectly when I took it out .
Hey thankyou so much for the responce!!! I was beggining to think all hope was lost for this thread :) haha
Anyway, it was my understanding that a aod with a aftermarket manual valve body didnt have a tv cable...Im still confused as to where this little piece is located, I'll look it over again.
Also what is the inspection plate? Sorry Im new when it comes to all this terminology.
Also did you do all this with your car jacked up? Or did you have it on a lift? Just trying to get a mental picture. Thanks so much bud!
P.S. I would so take you up on that offer for the auto, If you want to get rid of it, I'll gladly pay for the shipping :) hehe
Not 100% sure about the aftermarket valve body and TV cable but pretty sure it should still be there so the tranny knows when to downshift unless you shift it manually .
The TV cable will sit right next to your throttle cable under the throttle body and run down to your tranny to the kickdown lever which sits just above and in front of the shifter linkage .
The inspection plate is a small plate held on by 3 bolts that sits under the bellhousing facing the front of the car . just remove the bolts ond you will see the torque converter .
I did my swap in my garage with my car on jackstands , I did place the jackstands on cinder blocks to get it up just a little higher .
If you have any other questions let me know and you can have the tranny if you want it , its just sitting in my garage collecting dust .
Ok I checked the TV cable, its still there, attached. So all is well in that department :)
I have a buddy who works at a paint shop and I think he'll let me use his lift and tranny jack. If so that will be a true blessing! Plus I found a Honda crx sitting in a field, I contacted the owner and its been sitting there for 3 years and he wasnt sure what was wrong with it but he'd let it go for 250$. Im going to pick it up today and get it running so Ill have a daily.
I will definately be interested in that tranny of yours. Curious how much your asking? Thanks again. Your help is truely appreciatted.
OK I got a quote on pricing. With your own packaging, in a 3x2x2 box with a net weight of 100lbs shipping from zip code 32003 to zip code 79015 (where I am) it was 56.93.
I shipped honda trannys all the time after selling them on ebay. Id just go bix up spare boxes at Walmart. If this is something your willing to do, Id owe ya big time. If you have paypal, I could set up payment that way:) Just let me know whatya wanna do and I could give you my ph. # is need be.
Thankya sir.
Thankya sir.
no problem man , I can probably just strap that sucker to a palete , it would have to be one heck of a sturdy box to hold that . my zip here is 34207 . shoot me an E-mail - [email protected] with your info . As far as payment I can just have DHL send you a bill .
yeah talk about a very nice guy!
As far as boxing it up, I always just double boxed and threw in some styrofoam peanuts and bubble wrap. Worked everytime:)
Im not sure how much they will charge for a pallet. If you can find out for me thatd be terrific! Im stuck here at college walking everywhere and its quite humbling. Hah!
Thanks so much!
