K-member brace question...
click
142
I'm having some clunk/thunking when i come to stops or when i'm just starting off in gear, or at slow speeds when i turn. I've saw that people suggest to tighten the K-member brace first, but my question is where do i find it lol. I'm a suspension retard.
THANKS
you got a vert?
If so put it on ramps, jack stands, whatever and you will see a big brace taht goes right under the oil plan. Tighten all of the bolts on that and it should go away.
Chris
For the verts, its a fairly large brace that has several bolts.. You will see which bolts are holding it on (tighten those of course)
For a coupe, its a rather small cross brace that uses I believe two bolts.
While your at it, you might want to check other items such as..
-tightening up the strut bolts/nuts (bottom and top)
-tighten up the caster/camber plates,
-tighten up the Balljoint nut
-check the tie rod end links
-check the Steering rack bolts
and purchase a Hanes or Chilton manual if you do not know what, or where to find the above listed parts/bolts..
