k-member swap questions
i would like to swap out tthe k-member and a -arms for lighter lbs and easy eng bay access.
i don't need the camber plates, shocks, springs and so on.
i just need the k-member and the a-ares.
maximum motersports says that there kit requires that it has the other parts.
is there anther kit that i can get so i can re-use the stock parts but still swap out the k-member and a arms?
if you can find the style that uses the stock springs maybe. the upr kit requires cc plates, but it comes with the coil over bodies in the full kit. that do work with stock struts.
