K&n Issues?
  • Thread starter Thread starter rabidscoobie
  • Start date Start date Oct 12, 2017
  • 3
First Prev 3 of 3
Admin Dude
Jan 4, 1985
43,363
21,570
234
Box behind Walmart
Oct 21, 2017
#41
  • Oct 21, 2017
  • #41
imp said:
I've pushed stethoscopes on numerous forums, and the response suggested I'm some kind of a$$hole.
These two things are not mutually exclusive.
Reactions: imp and General karthief
rabidscoobie
616
12
48
College Station,TX
Oct 21, 2017
#42
  • Oct 21, 2017
  • #42
Well took it apart and cleaned it, really wasnt very dirty at all so I suspect it isnt going to fix the issue but the morning will tell.
rabidscoobie
616
12
48
College Station,TX
Oct 22, 2017
#43
  • Oct 22, 2017
  • #43
Nope, didnt fix it.
General karthief
Mod Dude
Aug 25, 2016
28,051
10,675
213
polk county florida
Oct 22, 2017
#44
  • Oct 22, 2017
  • #44
I still say you have a piece of that tornado thing stuck someplace. Have you checked the inside of maf housing
Where did you find that tornado thing at?
rabidscoobie
616
12
48
College Station,TX
Oct 22, 2017
#45
  • Oct 22, 2017
  • #45
I checked all through the entire duct,nothing in there except that tornado thing. It was sitting in the duct after the MAF housing but before the throttle body.
The tornado thing is intact,it is suppose to have that gap. Its a springy metal...if thats what your meaning. But if your talking about where it looks like there is a sticker missing then I cant find anything in the air box,duct,throttle body or upper manifold.
I cant seem to find a single problem that is sticking out as obvious.
rabidscoobie
616
12
48
College Station,TX
Oct 22, 2017
#46
  • Oct 22, 2017
  • #46
Ok removed each section of the air duct until the sound stopped....well it never stopped.
No air duct connected at all and the sound is coming from the throttle body or upper manifold. Replaced the IAC gasket since it was really brittle and still nothing. Checked the upper manifold bolts , couple seemed kinda more loose than others, torqued them down and still nada.
Now any ideas?
EDIT:
I also checked the vacuum lines and looked good. Couple years ago I replaced them anyway since they were pretty dried out.
imp
Mustang Master
Jul 13, 2017
531
105
83
Oct 22, 2017
#47
  • Oct 22, 2017
  • #47
I seem to have the idea that my engine won't run at all to allow me to listen to sh!t with all the inlet ducting removed......
imp
rabidscoobie
616
12
48
College Station,TX
Oct 22, 2017
#48
  • Oct 22, 2017
  • #48
I left the maf sensor plugged in and yes it did run. Ran well enough that now I know the sound isn't coming from the duct. With the duct removed it was much louder on that sound I'm trying to find and now that sound is clearly coming from the throttle body/upper manifold.
What's causing I do not know but tomorrow I will be looking further into it since it wasn't even cool this afternoon and it's making noise now, so it seems to be getting worse.
Admin Dude
Jan 4, 1985
43,363
21,570
234
Box behind Walmart
Oct 23, 2017
#49
  • Oct 23, 2017
  • #49
Its time to pull the intake plenum.
General karthief
Mod Dude
Aug 25, 2016
28,051
10,675
213
polk county florida
Oct 23, 2017
#50
  • Oct 23, 2017
  • #50
I still think there is a piece of that thing stuck in there someplace
rabidscoobie
616
12
48
College Station,TX
Oct 23, 2017
#51
  • Oct 23, 2017
  • #51
Yeah think I'm going to be pulling it soon.
This morning was cooler than normal so the sound was there from 750-1500 rpm's. But when revving between that the sound didn't change with revving, just kept the same droning howl and didn't change with engine speed.
rabidscoobie
616
12
48
College Station,TX
Oct 24, 2017
#52
  • Oct 24, 2017
  • #52
Pulled the upper off and saw nothing that looked wrong. Went ahead and cleaned the throttle body with a brush on any buildup.
No foreign debris. Also replaced any gaskets to anything I removed. Also had to buy a new EGR Sensor since I accidentally broke one of the hose nipples..damn those things are fragile and $70.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Oct 24, 2017
#53
  • Oct 24, 2017
  • #53
Weirder and weirder! If you were not so sure it was coming from that area I would try running it for a minute with the serpentine belt off.
rabidscoobie
616
12
48
College Station,TX
Oct 24, 2017
#54
  • Oct 24, 2017
  • #54
May try it anyway since Im running out of ideas.
That sound is for sure coming out of the throttle body.Definite air sound with the air duct removed. With the air duct the sounds as if it is coming from the air box but its just reverberating through the duct and causes a slight vibration on the air box.
I was able to reduce the noise some by using a sort of restricter plate that was custom made by another member here on a CNC machine for the IAC valve a few years ago. I never installed it since I didnt need it.He made a few of them and just gave them out to some here with Mach's best I remember.
The idea behind it was that at the time some Mach 1's had a hanging idle.This plate slightly changed the size of the holes to remedy that.
rabidscoobie
616
12
48
College Station,TX
Oct 25, 2017
#55
  • Oct 25, 2017
  • #55
Well so far its been quiet since adding that plate I explained above. So I dunno,maybe the IAC is failing. I'll just try this for awhile and see what happens.
Reactions: Neuron
rabidscoobie
616
12
48
College Station,TX
Oct 30, 2017
#56
  • Oct 30, 2017
  • #56
Still running quiet but my Control Relay Module (CCRM) crapped out over the weekend, there went $80.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Oct 31, 2017
#57
  • Oct 31, 2017
  • #57
What were the symptoms? Hope your car has gotten all of this BS out of its system LOL.
rabidscoobie
616
12
48
College Station,TX
Oct 31, 2017
#58
  • Oct 31, 2017
  • #58
Howling sound from throttle body.
Seems to be running good now.
But that control relay module I hate. Had to buy an $80 module just because the AC clutch relay went out. Whatever happened to just having old fashioned relays in the underhood fuse box....lol.
  • 3
First Prev 3 of 3
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
