  • SN95 4.6L Mustang Tech
K&N question...
  • Thread starter Thread starter JakeDaSnake
  • Start date Start date Jun 23, 2004
J
JakeDaSnake
43
Mobile Alabama
Jun 23, 2004
  • Jun 23, 2004
Ok im not gonna buy a hole K&N cold air kit cause its the same thing as the stock... I took the stock filter and the little platic thingy off and there is about a 3/4 inch lip there were the stock fliter fits but is that enough to mount a 4 inch cone filter on???
Later
Jake
V
VatStang
88
Santa Clarita, CA
Jun 23, 2004
  • Jun 23, 2004
The rubber inlet tube is corrugated, thus interrupts airflow after the MAF and to the TB. You hear guys say that different materials resist heat better, but honestly the the air hitting the tubing isn't moving slow enough to feel the effects of a heated surface. But, to your original point, you will feel a difference between a CAI and simply adding a K&N. You could simply cut the shroud around the filter and leave it exposed, but do not cut the metal strap looking thing. YOu'll need that to fasten the filter to the MAF housing. I myself think its useless to get a CAI if you do not install a new MAF, TB, and plenum.
J
JakeDaSnake
43
Mobile Alabama
Jun 24, 2004
  • Jun 24, 2004
will the metal strap hold the cone filter??? cause they have a hose clamp on them I always though thats what they were held on by...
Later
Jake
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jun 24, 2004
  • Jun 24, 2004
You could just do the open concical air filter like you're talking about, or, you can do the K&N FIPK setup which is what I recommend. I've had three different setups on my car. K&N air filter w/o silencer, BBK CAI, and the K&N FIPK. Out of the three, the K&N FIPK beats the other two hands down. The only draw back to the K&N FIPK system is its so damn expensive, however, it is about the best cold air kit available for our cars.
stangchef
31
  • Jun 24, 2004
I have the UPR CAI for like $119 shipped...Had BBK bottom half and didnt like it..Seems like the UPR reaches farther down in the fenderwell than most kits do also...and you can really hear it when you bury the throttle!
V
VatStang
88
Santa Clarita, CA
Jun 24, 2004
  • Jun 24, 2004
With the shroud you plan on cutting, just leave a bit around the two connecting peices. No, the metal strap is not enough.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
