http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=156886&prmenbr=361
Here is the link to these heads. My buddy just told me about them. Here are the specs on them
555-51501
302/351W Aluminum Head, Bare, Each
Specifications:
Casting: A356-A Aluminum, Heat Treated
Combustion Chamber: 60cc CNC Profiled Machined
Port Volume: 247cc
Valves: 2.100'' Int./1.600'' Exh., Stainless Steel, 11/32'' Stem
Pushrods: 3/8'' Heat Treated, 7.100'' Length for 302 Hyd. Roller, 7.750'' Length for 302 Solid Roller, 8.400'' Length for 351W Hyd. Roller, 9.050'' Length for 351W Solid Roller
Retainers: Chrome Moly Steel 10°
Rocker Studs: 7/16''
Valve Locks: 10°
Accessory Bolt Locations: Stock Placement
Head Bolts: Stock Dimensions
Rocker Arms: SB-Ford 7/16'', 1.6 or 1.7:1 ratio
Gaskets: Intake- Fel-Pro 375-1262, Exhaust- Fel-Pro 375-1486, Head- Fel-Pro 375-1011-2
THese heads flow 331 cfm intake @.800" and 210 cfm exhaust @ .800"
WHat do you guys think
555-51501
Specifications:
Port Volume: 247cc
Valve Locks: 10°
, and the exhast needs to be opened up just alittle
, i say for 800+ a head its not worth the money, e.i. get some AFR's, or Victor Jr.'s
whats that $512.50 a head fully assembeld, i love getting stuff when nobody knows not much about them can you say dirt cheap, in 1to2 years im sure these head will be $1500+, heck they go for $1200 but i got them at cost
