KB belt size help ASAP
Red1995GT
Lincoln, NE
I'm running the 2-1/2 supercharger pulley with the 6in. crank pulley. That should put out 8psi. Kenne bell sent me way to big of a belt for my application.
btw this is w/ a/c.
I called them and they said they don't know what size of belt i should use. I said WHAT!!:mad:
I can't measure the distance on the car because it is sitting in a dynoshop and i can't get a hold of the guy until evening. We trying to get a final tune then tonight but i have to have a belt the right size. Parts stores will be closed when i can finally get to my car. :bang:
So what i need, is if you have a 2200 series kennebell 94/95 at 8 or close psi what belt did you use ? length? parts #?
Any help would be greatly appreciated. Thanks in advance.
I'm not so sure that your dyno shop knows how to properly route the belt. I've seen LOTS of folks (including myself occationally) try and misroute the belt in relation to the blower pulley and KB bracket idler pulley. You may want to verify that they have the correct belt route going.
That aside,
Give Bob Kennedy a call at Kennedy's Dyno Tune.
He's a great guy and has installed more KB blowers than probably anyone on the planet. You can get his phone number form his website:
www.kennedysdynotune.com
