KC Clutch question
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date Dec 15, 2006
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Dec 15, 2006
  • Dec 15, 2006
I'm about to order a KC Clutch Kit to replace my old clutch. I know jack **** about clutches, installing them, ect. So this question may sound retarded to some of you....
- Will I need any other parts besides the KC kit when I complete the install? Such as; Clutch cable and firewall adjuster? Or is this an added option?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 15, 2006
  • Dec 15, 2006
When installing the aftermarket clutches, some people find it better to get a firewall adjuster. I would stay away from adjustable cables...and just get a stock cable (or keep yours if it is in good shape) and get a firewall adjuster if there is to much tension or slack on the cable.
You don't "need" one though.
Good Luck with it!
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Dec 16, 2006
  • Dec 16, 2006
If you do get a firewall adjuster and use the stock cable, you'll likely need an aftermarket clutch quadrant, too - preferrably one with multiple hooks (2, usually 3 hooks). Aside from being able to adjust the pedal height at which your clutch "catches," the other benefits of upgrading both pieces is that your clutch pedal will feel a lot more smooth and linear, not quite so grabby and random, and you'll be able to ditch the stock plastic pawl/quadrant setup that tends to get brittle and break (which can leave you stranded suddenly and/or wear out your clutch really fast).
I'd highly recommend checking out UPR for both pieces. They've usually got a deal going where you can buy the firewall adjuster and the three-hook quadrant as a packaged deal for cheaper than buying them separately.
As far as other things you should probably look into getting, if you don't already have them, or if they're needing it while you've already got things torn apart:
- Rear main seal (the Teflon RMS by Fel-Pro is a nice one, mine hasn't leaked a drop since I installed it)
- Steel input shaft bearing retainer (helps clutch engage/disengage more smoothly, prevents problems caused by a stock aluminum one getting too worn) and a new input shaft seal
- Polyeurethane transmission mount
- A couple of quarts of high-quality fluid for your tranny (might as well have everything nice n' fresh)
- New flywheel (it costs almost as much to have the old one resurfaced as it does to just buy a new one)
- A couple o' cans of brake cleaner (to clean off the clutch diaphragm and flywheel)
- Other stuff I can't think of at the moment.
HISSIN50
34
129
Dec 16, 2006
  • Dec 16, 2006
Things I might add to DW's list:
Pilot bearing
Inspect the fork pivot
Inspect the fork itself
Consider fresh flywheel bolts......
David (5Spd Gt, whom posted above) and Jrichker have posted very nice articles/synopses of the install - with part #'s as I recall.
Good luck.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
