so the trim around my windows and the rubber that goes against the windows is getting hard, can you armorall that stuff or is it best to leave it alone and let it dry rot?
No, that stuff is all done for when it gets hard. The moldings around my 88 doors I used on Hack Job just crumbled when I pulled them out. I bought the new stuff from 50resto and it fit pretty darn good for aftermarket stuff. Not perfect like the factory, but good enough. It didn't leak.
Maintain your new rubber seals by getting some silicon lubricant that comes in a spray can. Spray some on a cloth and wipe it on the seals. Don't use WD-40 or any oil based lubricant on rubber, it can degrade it over time.
I used WD40 on Hack Job to get them to slip in, but that's not the 1st choice to make. Silicone spray is the best choice. But, don't use silicone spray on your car if you plan on doing any paint work in the future. You will have fisheyes coming out of your a$$.
