Keeping 4 lug but adding rear disk brakes
With the stock 60mm calipers, and t-bird 45mm rear calipers, the correct MC is the 1993 cobra 1" MC
With the larger 73mm calipers, and the 45mm rears, the 1994-1995 mustang gt/v6 mc with 1 1/16" bore may work well for your application.
The svo with the 73mm calipers and 54mm rears use a 1 1/8" bore mc....so thatsmwhy insuggest the 1 1/16" mc may be the perfect match.
I don't have a pn since it's an auto parts store mc, and there are different brands. They can also be had for $20-25 used off eBay or junkyard
You may need to upgrade the booster as well...to 1993 cobra or 94-95 mustang
Didn't you do the swap without changing the rearend?
i have 4 lug also have SSBC rear disc brake kit, up front I have stock calipers with brembo slotted and drilled rotors with hawk hp pads my car stops great pedal feels nice very satisfied with braking. Really the only reason I would ever change to 5 lug is for better wheel selection.
