Keisler / The Driven Man / Modern Driveline, Inc.
Here's why I can't buy the Keisler claims. When I installed my TKO600 behind my stock 351/408W, I didn't want to cut the tunnel either. I lowered the engine and trans into the car as a unit, installed the motor mount bolts, put the jack under the tail of the TKO, and it was hitting the floor before I got anywhere near the stock 3.5 degrees on my angle finder.
No special crossmember is going to address that... and the 69/70s have more tunnel room than the early cars. So watch out, unless they somehow alter the TKO where those two "towers" are on top of the case.
http://www.geocities.com/gsxrken/Mustang/100_0649.JPG
My understanding from "The Driven Man" who sells Keisler Kits is that the TKO transmission is modified. This is a quote from their website,
"Retooled with new internal shifter rails, true internal offset, correct shifter geometry, permanent lubrication,
smaller profile for correct driveline angle and tunnel clearance. "
Their other details are here:
http://www.thedrivenman.com/KE/gm/transmissions/popup_perfectfit_benefits.html
Sorry, above is for GM-Thanks BarnStang. Here is the link for Mustang:
http://www.thedrivenman.com/KE/Ford/Transmissions/mustang_65-70.asp
"no modifications to your tunnel sheet metal, seats or console." However, I called The Driven Man and they stated that a "notch" would have to be made to the brace found in the transmission tunnel.
KiwiGT,
regarding your T5Z, is this T5 transmission rated at 450 hp?? I read that the clutch is 450 hp, but I thought the T5 Z was rated at 330 torque. I thought your engine had more than that (450 hp and 420 tq).
I also got this quote from Bruce at Modern Driveline, Inc., but I failed to ask if their T5 Z could hold over 400 torque.
65-66 Mustang T-5 450hp
New T-5z 2.95 first .63od
$ 1,395.00
T-5 bellhousing adapter plate
$ 160.00
Flywheel lightened billet steel 28oz.
$ 295.00
10.5" Kevlar\Kevlar Clutch kit
$ 450.00
Flywheel bolts
$ 17.00
Pressure plate bolts
$ 12.00
Hurst Chrome lever
$ 59.00
Hurst shift ball 5 sp. Pattern
$ 39.00
Hurst shift boot
$ 26.00
Speedo cable
$ 26.00
65-66 mustang T-5 crossmember
$ 149.00
T-5 transmission mount
$ 19.00
Speedo gear
$ 9.50
Amsoil ATF oil, 3 qts
$ 29.85
sub total
$ 2,686.35
Optional equipment
Steel Driveshaft with yoke
$ 325.00
Aluminum Driveshaft with yoke
$ 425.00
28 spline yoke only
$ 85.00
Fulcrum kit for T-5 bellhousing
$ 43.00
OEM appearance shift lever
$ 139.00
OEM appearance shift ball
$ 39.00
Lower cluster billet steel plate
$ 60.00
Slik Stik Shifter (clears shifter opening)
$ 295.00
Hydraulic kit with master cylinder
$ 495.00
Scatter shield
$ 375.00
Aluminum Flywheel
$ 395.00
