for a street car i'd say a KB would be a good choice.
sure the no intercooler is a drawback but i wouldnt be super worried about that unless your running alot of boost.
if you have the PC or vortech, pullied for 10 psi of boost at redline, your going to PEAK 10 psi, so what happens is you WONT have that much boost in the midrange, which IMO is what gets a car moving.
with the PD style blower, pullied for 10 psi means 10 PSI ALL THE TIME, more or less its just an amplification of your current powerband. at lower rpms and int he midrange, your going to have that 10 psi of boost instatly, instead of having to tach the car to higher rpms to get the higher boost beacuse the midrange you only see half that
granted the centrifugal compressor is more efficient, its just all about how much power your going to make and what you want from the car. if going to an all out balls the wall drag oriented car, thats only going to see higher rpms at the track, the centri blower would be awesome. but for a street car that is going to be driven around alot. the instant torque from the full boost at will is great.
i myself ran a vortech, while the power it made was KILLER on the top end, i felt the lower and midrange wasnt much more than N/A, dont get me wrong the vortech rocked and made alot of power, but since my car is mostly cruised on the street, i wanted more pull in the midrange. so i'm fixing to do a turbo setup, to me a turbo is sort of the best of both worlds, has more boost down lower (assuming its matched up right) and has the good effieciency of the centri style blower. plus i have always wanted to do a turbo setup, but the roots would even come in sooner than a turbo.
if you all that worried about inlet temps, you could run some meth injection. but i dont see what you shouldnt be able to pull off 10 psi without a problem. you could even make the tune a hair extra rich and keep the timing conserative to give yourself a cushion.
boost down low FTW
but honestly either way it will help out a ton and run like a scalded ape with either the KB or PC
