  • SN95 4.6L Mustang Tech
kenne bell owners
  • Thread starter Thread starter Saleen s281
  • Start date Start date Oct 28, 2004
1 of 2 Next Last
Saleen s281
79
flushing new york usa
Oct 28, 2004
  • Oct 28, 2004
hey guys just wondering if anybody figured out whats causing our cars to pause when switching gears? i heard that theres not much we can do but power shift so that it wont pause.
B C
444
Chino, CA
Oct 28, 2004
  • Oct 28, 2004
I find it helps not to let off the gas too much, kinda half way let off the gas when you shift. You might try calling KB and see if they can give you some advice. They have been of great help to me whenever I have had questions.
U
USMC_MuSTaNG
82
south carolina
Oct 29, 2004
  • Oct 29, 2004
mine still does it after 3 chips.....guess it is something we have to live with. just shift faster....seems not to hisitate that way.
Y
YellowJacketGT
108
  • Oct 29, 2004
Had similar problem.. Proper tune made it disapear. There is a setting called tipin. This retards timing when you initially go into WOT. You may have to back off a bit.
Also , if your air intake temerature is a bit high, usually occurs third and forth gear, a slow shift will cause RPM to drop (as much as 1000 rpm). The settings for timing and heat may actually cause detonation if not set correctly. This may only be an issue with higher boost applications.
J
JSTaGT
76
Methuen
Oct 29, 2004
  • Oct 29, 2004
I don't have it on mine. 14# custom tune by MPH aka T&J Performance.
U
USMC_MuSTaNG
82
south carolina
Oct 29, 2004
  • Oct 29, 2004
Yes Tim did mine too. JUst can't find out what is making it do it. He even gave me a tune from smithatlanta's car(that doesn't do it) and i still have it. Go figure.
01MustangGT
202
CA
Oct 29, 2004
  • Oct 29, 2004
it happened like that to me 3 times when i shifted from 2nd at 5700 rpm to 3rd. The fourth time, my rods were gone. Now i had my engine rebuilt and stroke to 5.1L.
I will for sure have my car dynoed tune after i have my new motor.
Don't push it too hard or u will have to spend 6 grand on the engine
neoclasiccl
3,043
Help I can't see !!!!!!
Oct 29, 2004
  • Oct 29, 2004
Tim tuned mine out also.
Saleen s281
79
Oct 29, 2004
  • Oct 29, 2004
has anybody called kenne bell?
01MustangGT
202
CA
Oct 29, 2004
#10
  • Oct 29, 2004
  • #10
i didn't call them, i just post in Kenne Bell tech on modularfords.com.
btw, Saleen s281, i were using KB tune when my rods broke. check ur pm
Y
YellowJacketGT
108
#11
  • Oct 29, 2004
  • #11
This actually happend to me at the track. Back to back runs. I believe the intake air temperature increased significantly. A slow shift caused the RPM to drop about 1000 rpm. Timing plus increased heat may have cause some detontation to occur hence the issue. I plan to have my tuner reduce some of the timing from around 4500 to 5000. I will also make sure I have at least 100 octane mixture when I go to the track.
You can dyno all day long in 1 gear. This issue is multiple 4 gear runs. I am at the point where I am considering water/methonal injection to address these Ait Intake heat issues.
Saleen s281
79
Oct 29, 2004
#12
  • Oct 29, 2004
  • #12
01 mustang gt how much hp& tq did u make when ur rods went?i was also told by jim from jdm performance that this pausing wont cause engine damage. also what was ur 1/4? i ran a 12.722@115 on street tires
B C
444
Chino, CA
Oct 29, 2004
#13
  • Oct 29, 2004
  • #13
You need slicks. 11.91 @ 115 here @ 9 psi. And that run was far from perfect weather or a perfect run. I plan to go to the track the next few weeks and I am almost certain I will run faster than that.
Saleen s281
79
Oct 30, 2004
#14
  • Oct 30, 2004
  • #14
yea i do need slicks! what size rim and slick would fit on my car? how much hp and tq do you have bc?also what are u plaining on doing with this pausing problem.
B C
444
Chino, CA
Oct 30, 2004
#15
  • Oct 30, 2004
  • #15
I am running a 15"x9.75" rims, 6.5" bs, 10"x26" slicks with stock 3.27 gearing. I had to grind down the brakeline bolts with the Bullitt brakes to make the rims fit. I am at 400 rwhp and 410 rwtq. I don't have a pausing problem if I keep my foot in the throttle a little bit.
Blue Blurr
279
California
Oct 31, 2004
#16
  • Oct 31, 2004
  • #16
are you guys talking about the slight hesitation when u give it gas. like u give it gas and the rpms raise just a tad and then it kicks in? if so mine does that too. i just got it on my car today very happy. i can handle the hesitation it isnt that bad.
01MustangGT
202
CA
Oct 31, 2004
#17
  • Oct 31, 2004
  • #17
i got like 375 rwhp and 386rwtq with a clutch that is slipping so badly. And after i got my centerforce dual friction on, broke the clutch in for a new dyno but unfortunately, the rods are gone before i can make it to the dyno shop
E
el_kid_1
738
Puerto Rico
Oct 31, 2004
#18
  • Oct 31, 2004
  • #18
I have not nocticed the hesitation you guys are talking about. May be I need to drive more my car and pay a bit of more attention.
E
el_kid_1
738
Puerto Rico
Oct 31, 2004
#19
  • Oct 31, 2004
  • #19
Hi BC,
Are you running on stock axles as wells?
03trubluGT
1,067
Mansfield, TX
Oct 31, 2004
#20
  • Oct 31, 2004
  • #20
I haven't noticed it either, guess I'll pay closer attention on the drive into work.
Matt
1 of 2 Next Last
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
R
Kenne Bell Supporting Mods for 2002 GT?
  • Rembrant
  • Mar 25, 2025
SN95 4.6L Mustang Tech Mar 25, 2025
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
