i got it used, but there is alot of stuff in the box he gave me. can you post a pic of the bracket?KBCobra95 said:You are supposed to mount it behind the power steering pump. Should have come with a black bracket.
excellent page, but a couple of the links don't work ...ej95cobra said:It attaches to the front of the exhaust manifold with the nut and bracket notch toward the front of the car.
Go to www.schwarzmann.com to find the complete installation instructions. Check out the garage section, it has the whole installation manual posted. Figure 14 shows mounting bracket installed.
pics please, thanks!MattZ281LE said:I mounted mine with the KB on the driver shock tower with the suplied bracket bent down and attached to the strut tower brace mounting holes. Worked VERY well. Mounting it where KB says works if you have stock headers but not large tubes. And I liked moving it away from the heat.
I can post picks if you like.
