Hey everyone,
I finally joined this site after browsing it for years. I'm a foxbody guy, but was working on a friends 94 GT today.
Heres the issue:
Car starts / runs / drives normal, when you turn the key switch off it stays running. Got the engine shut off by pulling the coil wire. With the key in the off position, the radio / heat n air conditioner / power windows / windshield wipers will not work. The dash warning lights stay on, and the coil and fuel pump both have power. I removed the key switch tumbler (its older but still functioning) and tried a different one. Same results. Next I removed the actual "switch" that is operated by that little rod on the bottom of the steering column. When I slide that the little rod on the switch, the warning lights on the dash stay on, but the radio and everything comes on like normal in the correct positions. I can even push that little rod on the switch all the way forward and start the car correctly. Thinking this switch was shorted out, I took the screw out of the connector and unhooked it. Dash lights still on, fuel pump and ignition coil still on. What am I missing? Is there another "switch" on the column that is operated by the keyswitch tumbler? I thought the one on the bottom side was the only one. Unhooked the negative on the battery cable for the night so it wouldn't die.
94' GT 5speed hard top
Mostly stock engine wise.
Never had this issue until today.
Heres the issue:
