Kill switch help
94v6GT
141
im helping my buddy put a kill switch in his car (95cobra) he was going to do one off the clutch switch, but i told him someone could still push start it.(right?)
Is there anything else under the dash we can use? :shrug: he doesnt want to go through the firewall
its a DD street car, he doesnt have his batt relocated. jus something to prevent his car from being started.
Are there any wire under/behind the dash that can disable the car? anything coming off the ecu:shrug:
On 94-95's, the FP relay is in the CCRM under the hood.
Be careful of cutting anything with the ignition or fuel system. If the switch fails or a connector comes off, the car will stall. If this happens while making a left turn in front of traffic, that could be bad.
Back in the day, we'd put a keyed valve on the fuel line. The lock came up through the passenger floorboard, where you could put the key in and turn the valve.
If you want to do a clutch kill, just put the switch in series with one leg of the wiring going to the switch.
