FINALY, I have the 94 back up and together...got the last PITA issue fixed (alt. was not getting a ground threw all the powdercoat).
I have a question about the J4J1 speed limits. When I set up my speed limits I did the 16xxx thing and have been looking at some of the what seems to be "newer" info. Is this the correct way to kill the speed limits on our processor?
Last year I was having an issue with my J4J1 tune at the track, with a VERY basic T4M0 tune with only the inj. changed for the 24's very basic with the 24 and 24 x's 1.2 for slopes and checksum set to 0. I picked up like 3 tenths and 3mph with the 100% stock timing tables and 10* base.
Now I know I had some valvetrain issues that I sorted out. However, I have been thinking the speed limit kill info thing was kinda old and might have more for the fox stuff and not the same for our 94-95's. Picking up so much from such a basic file has me thinking I have mine setup wrong as the drivability is great but WOT perf. was soft.
Nothing else I had messed with on the J4J1 should have caused this other than what I found out about the breakpoint/slope being a mix of J4J1 and T4M0 issue that I think had the major roll...just want to make sure its not the speed limit as well.
Sorry for the long read...and thanks.
j4j1 speed limit
. The biggest reason I have the timing on the lower side. I have 93 avail. at 90% of the stations around...then QT (local-ish chain) just dumped there prem. to 91 (but I only get there gas as a last resort). I smoothed out my chambers so that should help fight off the det. also. Depending on the production var. of +/- 2cc on the heads and the smoothing I am around 10.33 and 10.66 to one on compression...so I deff. want to keep it lower until I double check the A/F. On the old stock maf it was dead on from the dyno session...diff. stock maf now so who knows...I think I may be the only person running a 98 GT maf on a 94 GT.
