I bought the car used and I am almost positive it has a kirbin on it. From the looks of it on the car and what pictures of the kirbin look like online, it is a match. Anyway, I read that a feature of the kirbin is that you don't need to remove the vaccuum line to read the pressure. (I have a gauge where the schrader valve was). It reads close to 40 with the vac line on, but if I take it off, it is around 45 or higher. Can anyone confirm this that I can leave the vac line on to read the gauge at idle. When I rev it, the gauge goes to about 36psi. In the morning the car doesn't want to idle and will pop out the intake a few times then clean up. Adjusting the FP hopefully will fix it. (I hope). Thanks in advance.
