Knockin cold
Couple of things:
1st-
When I start my car in the mornings, it seems to knock a little bit. Almost as if you're lightly knocking on hollow wood or something. I'm assuming this is the rocker arms that are knocking a little bit b/c the oil pressure is high and everything hasn't been lubed up properly.
Is this normal? B/c it seems to go away once the engine is warmed up and the oil pressure drops.
2nd-
If it IS the rocker arms, than I'm thinking about going with some new roller rockers. Now, I don't know what kind of rocker arms are in this vehicle b/c I've never opened it up and looked before. However, I would assume they are regular rockers. Either way, does anybody have any advice for some good roller rockers I can install that would hopefully get rid of the knocking?
Whoops! I just checked my oil and it's reading minimum instead of maximum. That's probably why it's knockin when it's cold.
However, I checked my engine for oil leaks and and I don't see any. Is it normal to burn oil if you run your engine HARD everyday?
