Knocking! Help!
  • Thread starter Thread starter DRock9
  • Start date Start date Mar 27, 2007
D
DRock9
359
  • Mar 27, 2007
I hear the noise when I am on the highway sometimes, last night I was in 5th gear at 1,600RPM going about 70MPH and I hear a knocking coming from the engine. I hear it from time to time but not always, is it detonation? What could be wrong with my engine?
I used to be able to cruise around at about 800-900RPM in 5th gear and slowly get on the throttle if I wanted to accelerate a little but I had a tuneup done after my car started to badly misfire and ever since then it doesn't like it...I also get a weird "bump" in the shifter most notably again when I am in 5th gear. When I am driving and I go to accelerate I can feel the shifter sharply move a little bit from side to side, and when I push the clutch in it's gone.
I am unsure of what either of these problems are seeing as I am not a mechanic but i was wondering if anyone else could help diagnose them.
Thank you!
EDIT: There is nothing really "pingy" about the first noise.
TomCat
412
Utah
Mar 27, 2007
  • Mar 27, 2007
Random thought... take a look at your motor/trans mounts. When my stock type ones were torn, it made really weird clunking noises all the time. Might as well take a look for fun
Good luck!
D
DRock9
359
  • Mar 27, 2007
Clunking noise only happens in the described situation.
D
DRock9
359
  • Mar 28, 2007
Anyone?
D
DRock9
359
  • Jun 7, 2007
Bump!
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
