Progress Thread Komo's 1990 GT - Parts Gathering Purgatory & Home Remodel
  • Thread starter Thread starter gkomo
  • Start date Start date Sep 23, 2024
  • 92
  • 93
  • 94
  • 95
  • 96
  • 104
First Prev 94 of 104 Next Last
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 13, 2026
#1,861
  • Apr 13, 2026
  • #1,861
RaggedGT said:
I’ve always used parts house branded Sn/3G alternators without much issue. Have you checked the diode/connection/wire to the alternator ?
I haven't. Car is so damn low and the alternator is relocated to the bottom of the engine due to the supercharger so its not easy to get to without ramps/jacks, which of course, are buried in my garage at the house.
nicholase said:
Have em tested. Go from there.
My PA performance alternator seems good so far. They are 100% new parts, not rebuilt.
On the battery, remember the leads on our batteries are reversed from typical. So consider the length of your cables on if they will work with whatever battery you go with. Just something to think about if you haven't already
Also, the AGM batteries are taller. I just went through this, so you'll want to do some measuring first. Didn't work out for me....
I'd probably toss a battery in there either way. You were saying it's due date is here I believe.
Ah ok. I've been reading a lot on this battery 'upgrade' and a lot of people have said they pop right in. Might be brand specific on dimensions then. But when looking for alternators i'm looking for a 94/95 alternator, correct? Or is it like a Fox 3G upgrade specific alternator?
The more i'm going through all this, the more i think it may be time to just throw in the towel, drive the car to the house and park it until we move back in. Too many things keep popping up that I just can't fix at the moment and its just making me frustrated.
AeroCoupe
5,989
4,112
183
54
Claremore, OK
Apr 13, 2026
#1,862
  • Apr 13, 2026
  • #1,862
When I got mine (I asked for an alternator for a 1995 GT) it was only another $20 or so to get one that had the lifetime warranty vs a one year at the parts store so that is what I went with. Have never replaced it.
Reactions: gkomo
nicholase
I lubed and pushed, until it was all the way in
May 21, 2024
641
1,144
103
New York
Apr 13, 2026
#1,863
  • Apr 13, 2026
  • #1,863
Could be. I noticed all the AGM batteries were taller by the online measurements. My issue is the negative cable. It sticks out from the clamp a few inches. It's what hits the hood. So I could probably change that and maybe one would fit.
Had enough going on and didn't feel like changing a brand new cable so.....
I'm using a fox 130a 3g. I'm sure there are other ways.
Yeah, its tough. Try not to let it get ya down. It's temporary.
Reactions: gkomo
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 13, 2026
#1,864
  • Apr 13, 2026
  • #1,864
ha ha just gotta laugh some things off. NO rain in the forecast today, so I drive the mustang to work. I'm out on our production floor and I start to hear what sounds like someone moving a pallet jack around, but there is a sneaky suspicion in the back of mind it's not. I look around, no one moving anything. , its rain on the roof, so I go to our front door and look out and it's like the most torrential downpour happening. Run out to the Stang quickly to grab my bubble wrap vent covers, existing tape is making them stick to each other in bunch balls, I'm fumbling to get them separated and straight as fast as I can all while getting soaked. F it, tape is obviously not sticking to the wet paint so I just jam them in the vents covering them the best I can and run back to cover. Completely drenched, like as if (mainly the backside of my clothes) I jumped in a pool. Now I'm sitting here, wet clothes, wet socks, wet shoes, wet chair, wet hair, cold as hell because this damn building keeps the AC on full blast.
All for like 10 minutes of unexpected torrential rain.
Reactions: 85GT4V, 91AOD5.0LX and DadLife0724
nicholase
May 21, 2024
641
1,144
103
New York
Apr 13, 2026
#1,865
  • Apr 13, 2026
  • #1,865
Lol. You out there like Lieutenant Dan
Reactions: Noobz347, DadLife0724, gkomo and 1 other person
Admin Dude
Jan 4, 1985
43,200
21,377
234
Box behind Walmart
www.stangnet.com
Apr 13, 2026
#1,866
  • Apr 13, 2026
  • #1,866
Why are we running out to cover the vents from rain?
What gets wet?
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 13, 2026
#1,867
  • Apr 13, 2026
  • #1,867
What gets wet?
I mean engines can get wet I get it but the drivers vent is right above the battery and some coil (ish) area wiring ( a little more so above the header). The passenger vent is directly above the supercharger head unit and pulley/belt as well as the inlet/discharge pipes, drive belt and smog pump and alternator assemblies that are under that area as water drips downward.
Admin Dude
Jan 4, 1985
43,200
21,377
234
Box behind Walmart
www.stangnet.com
Apr 13, 2026
#1,868
  • Apr 13, 2026
  • #1,868
Hmmm... I'm thinking that by the time your headers get warm that the water is mostly gone.
Reactions: gkomo
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 14, 2026
#1,869
  • Apr 14, 2026
  • #1,869
I'm more of the mindset if i can keep water out of there the better. I don't want things unnecessarily rusting or water getting into wiring. The rain was heavy and blowing pretty good sideways as it was windy so I can't be certain exactly what was/would get drenched.
But yes, i'm sure my drive home heated everything up enough to evaporate the water that did make its way into the bay.
Reactions: DadLife0724
General karthief
20+ Year Stangneter
Aug 25, 2016
27,960
10,602
203
polk county florida
Apr 15, 2026
#1,870
  • Apr 15, 2026
  • #1,870
My question is, while looking cool and may be functional, is it worth it?
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 15, 2026
#1,871
  • Apr 15, 2026
  • #1,871
Necessary, no. Worth it, yes. Normally I would have a garage to park it in so it wouldn’t be a problem. When I put the vents in I did not factor in the long ass home renovation that has displaced us and relegated the Mustang to street parking during the rainy months.
Although in this specific instance there was no rain in the forecast (showed all sunny) and then we get 10-15 minutes of torrential downpour… so having access to my garage wouldn’t have helped on this case. A fluke situation that should be rare.
Reactions: 85GT4V
nickyb
I gotta say i never painted my nuts, Never Ever
2,980
1,627
153
63
nevada
Apr 15, 2026
#1,872
  • Apr 15, 2026
  • #1,872
Soooo if your on the freeway and it starts to downpour ???
That won't look so cool
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 15, 2026
#1,873
  • Apr 15, 2026
  • #1,873
Well, driving at speed actually wouldn’t be a problem because the vents are setup where they pull air out from the engine bay so at freeway speeds in rain I would expect to see water being pushed back upward above the hood. Now at low speeds it is a problem.
But, I just typically wouldn’t be driving it in the rain. Also, big also, I wouldn’t have put these in if I didn’t live in San Diego. We don’t typically get a lot of rain or general foul weather, I just got caught randomly in an unexpected short rain storm. The DD 4Runner takes on those duties.
DadLife0724
299
206
53
Cooperstown, PA
Apr 15, 2026
#1,874
  • Apr 15, 2026
  • #1,874
Are those vents metal? If so, some sort of magnetic cover would be the ticket im thinkin. Easy on, easy off.
Reactions: gkomo
Admin Dude
Jan 4, 1985
43,200
21,377
234
Box behind Walmart
www.stangnet.com
Apr 15, 2026
#1,875
  • Apr 15, 2026
  • #1,875
Just keep a light weight car cover in the trunk already.
sheesh
Once you get used to it, it takes like 30 seconds to toss a cover on. Another 10 to lean over and pick up the coffee and briefcase you set down, depending on the kind of morning you're having.
You're putting it on a dirt car, so one with that fuzzy kind of inner lining is best for this.
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 15, 2026
#1,876
  • Apr 15, 2026
  • #1,876
They are and that’s something I need to do (and has been suggested previously). I wonder if my mom could sew me something up… I don’t possess those skills.
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 15, 2026
#1,877
  • Apr 15, 2026
  • #1,877
sheesh
Haha I have one. Car was so dirty though I didn’t want to put the cover on it and scratch the paint or get my cover dirty. But my paint sucks anyways so who am I kidding.
Reactions: General karthief
91AOD5.0LX
I have a slight sag in my rear
5 Year Member
Feb 20, 2021
1,066
997
133
Lake George NY
Apr 15, 2026
#1,878
  • Apr 15, 2026
  • #1,878
This may be an option?
Magnetic sheets to drop down over the hole and then lift up when your done.
Plain Magnet Sheets,10PCS,8.5''x11''Flexible Rubber Magnetic Sheet,30Mil Non-Adhesive
https://a.co/d/0j25XwOL
Reactions: General karthief, DadLife0724, nicholase and 2 others
gkomo
Aug 2, 2024
2,209
1,440
133
San Diego, CA
Apr 15, 2026
#1,879
  • Apr 15, 2026
  • #1,879
This is a great idea and will steer me in the right direction. I just need a 10" x 23" (approx) size, but something like these would work great.
Edit: something like these:
https://www.amazon.com/Flexible-Magnetic-Sheet-Rounded-Corners/dp/B00W80V3HE/ref=sr_1_7?crid=7SO1IY2BAENE&dib=eyJ2IjoiMSJ9.OV5YQI7gmuWzCaJpxHUAg1YTXSEAKHM1Ixhln0y4TsjS7QYAJaC8uSc0yNe-GVBPJl90vwCI-VEBHLe5dPZpP6E8Xq0ZGPo13uOQTx5Ur7Xah472NvqA1thYGYTqL9q-EeU2XV7Yt6D5z1IL71SmjjqTtTH6CafMet0y5GMLU8EtcDeO5FdPDN2cEnTfE_RcinbKMeY-eHLJzwj9Wajjvq67G2TUXpdggCwsGFbdov49EbMX1O6OHne_0eWst4jiHpHUymwmkpZzO2g6_R3jN-kA3aaLNy2rfFMp2YwyaIE.dcsdhD8MdgNl_XE-eD_aPKRruUz0QI8pZ7anxlpQt2M&dib_tag=se&keywords=magnetic%2Bsheets%2B12%2Bx%2B24&qid=1776292171&s=office-products&sprefix=magnetic%2Bsheets%2B12%2Bx%2B2%2Coffice-products%2C215&sr=1-7&th=1
Edit 2: ordered, thanks again for the idea. Totally didn't even think of these car 'signs' as an option.
Reactions: 85GT4V, DadLife0724 and 91AOD5.0LX
Admin Dude
Jan 4, 1985
43,200
21,377
234
Box behind Walmart
www.stangnet.com
Apr 15, 2026
#1,880
  • Apr 15, 2026
  • #1,880
If you had a hair on your ass, you'd rig up a vacuum operated vane system like the cowl on the old IROC.
Reactions: gkomo
  • 92
  • 93
  • 94
  • 95
  • 96
  • 104
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Rear drums dragging
  • cnorman31
  • Apr 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 15, 2025
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
