basically uca's that are adjustible are for the drag racing crowd that have full spools and never see corners other than at the end of the track in the turn around. like mensioned above get the 94-95 gt uca's and install them. suspension binds sucks and make your car very unpredictable...and thats even before you start pushing your car to the limit!
Chuck the ploy bushings that come with the arms in the trash and get a set of rubber bushings from your local Ford dealer to fit a 94/95 Mustang.
I got my bolt-in torque box reinforcements off of eBay although a quick check of some other "quality" bolt-in TBRs showed them all to be virtually the same. In fact the TBRs I got from eBay had the same instruction sheet as the ones that UPR sells.
Your car will definately feel much stiffer after the installation. Don't forget to get weld-in subframe connectors too.
I CANNOT buy the rubber bushings fpr this control arm. Looks like I am screwed then. Im having them installed anyway I guess This is the thread I started earlier about what to buy.
