lakewood driveshaft loop
hi i have the custom lakewood driveshaft loop designed for 87-93 mustangs installed in my car. Will it work with an aluminum driveshaft or will i hafta buy a special driveshaft loop? Just something I thot I seen somewhere b4 if anyone has any input.
thanks
It will work. But before you fire up the car make sure the bolts that connect the upper part of the circle to the lower section clear the driveshaft as you rotate it. Sometimes a wieght on the driveshaft and be in the way and you will have to adjust the loop a little.
