I just bought a new Laptop, but i cant get it to connect to the internet. We have a wireless connection here at the house, and the laptop supposeably has a built in wireless thingy. How do i make it work??????
you need to go to network neibor hood and see if you see a wireless link in there and if there is you need to click it and see if it sees your network if so just connect to it, if you dont see it in three i think you may have to enable it in the bios wich is more complex
I have this Mustang but it won't start... help! JUST KIDDIN. Do need some more info on your laptop tho to help you out...
What make/model laptop is it?
Do you have a wireless on/off switch on the outside of the laptop and it is ON?
Hold down the windows key (between ctrl and alt) and press "Pause/Break". Go to the "Hardware" tab and click "Device Manager". Under "Network Adapters", do you see a wireless network card installed? (It'll have a green icon beside it).
I know that back home, I set up a wireless network using SysLink. With that with that wireless network, you need to use their wireless receiver. I tried to use my laptop's wireless and it didn't work.
First off, is the wireless connection coming from a desktop computer? If so, you will need to "set up" the connection somehow. You need to go into the laptops wireless feature and (you need to know what you named your wireless network) search for it. It will usually find it.
OR, if it cannot find it, you may need to adjust some settings on who you let connect to the network from your desktop.
Also, yes, there is a definately an on/off switch. They all have them. It is probably pretty small and on the side somewhere. Probably the right side.
