slvr302 said:Larocca's are down right thieves!! I still have the same problem now after doing every single thing they suggested . Now they are blowing me off telling me my car is fine and take it somewhere else if I don't think so.
My problem: glowing catalytic converters
I spent close to $9000 there in the past 1.5 year plus I had to buy a new shortblock (not included in the $9000) because my newly rebuilt one blew up while they were dynoing for about the 20th time to see why my converters were overheating. They had my car 7 months and treated it like no one would want theirs to ever be. Left it parked under trees in a wet and weeded area across the street from the shop. Car looked like total $hit afterwards. Alot of my new stuff got rusty real quick.
My converters were glowing when I brought my car to them. They had me replace a brand new set of Roush 200 heads that were worked, a brand new Comp Cam XE274HR, my entire new MSD ignition, and my just rebuilt 306 after they killed it on the dyno. I was furious to say the least.
At this very point (before I went ahead with the new block) I asked Jimmy Larocca himself had my glowing converter issue been resolved. His answer was "Yes. Just go with the new sb from DSS and you will be good to go". So I decided to do so. This way it gives them no "out" to point the finger at anyone elses work if something doesn't work from this point on. I figured they have done everything and no one else has touched the car but them so there is no one else to blame.
Needless to say after the new motor was installed I came home with a very large bill only to my suprise to see that my cats were still glowing. I called back and said what the hell is going on. You told me that 100% my converter issue was fixed. Jimmy Larocca's answer was "If you converters are glowing now (as if they weren't before) then the converters are no good"
I couldn't believe what I was hearing. After I just spent all this money they have the nerve to give me that answer. Couldn't they have determined that before I spent $9000 + $2300 for shortblock????
So I said to them I will buy a new set of hi-flow converters (Random Technologies) and I should be good from here? Larocca said "Yes". The cats cost me $380 alone (not including h-pipe). But before I could put them on my brand new Vortech started making a crazy whining noise. Bearing was messed up. It was all rusty looking along with my entire blower bracket from sitting for 7 months in that damp a$$ area that they had it parked in. I called Larocca up to ask if they could take the blower off so I could send it for repair. They said that I would have to wait one month before they could get to it. So I had a friend take it off.
When I got it back from Vortech my buddy put it back on then I took it back to Larocca's just to make sure nothing changed with the tune. At this time I just put the new converters on and even went so far as to have the car towed to Larocca just so there was no chance of me screwing the converters up by driving it there out of tune.
End result: Converters still glowing!!!! Jimmy Larocca says that it's fine and there is nothing more for them to do. He then asks what gas I am using. I say Sunoco 94. He says "try another gas. Sunoco 94 is all hype and actually has less octane than others." Is this crazy or what??????
My entire center console is almost burning to touch and is warped from so much heat. The cats get cherry red after 4 minutes idling. My car could literally catch fire from this.
Forget about all that stuff you read in the mags about Larocca. It's all BS.
This turmoil cost me $9000 + $2300 + $380 and I am still at the same place as when I started.
You may ask yourself "why not just put an offroad h-pipe on and be done with it" My answer is "My car smells to HOLY HELL like you have never ever smelled in your life. Not even from an all out race car!!"
I am going to attempt to get some money back by any means necessary.
Comments anyone?
