Last 302 VS. 351W question I promise
Project 77
370
Bernville PA
OK as some of you know I went to look at a 351W lastnight, and the report is in. The motor is a complete fresh rebuild, .40 over, 30 pound injectors, and matching Prom M mass air meter. The only concerns I have are as follows.
1. Would the weight diffrence between the 302 and 351 cause a nose heavy condition, throwing off the cars geometry
2. I was told with the way the accessories are on the motor I would have to move the battery to the trunk and remove/notch the exsisting battery tray.
3. lastly, will it fit in an SN-95 without major cutting
I was told the motor dynoed at te flywheel at 525 HP. I was also told I could have the motor, installation, tune, and any other thing i needed for $5000. so which is better, a rebuild/stroker from my 302 or this 351W?
Thanks
Jerry Leaming
477
Olympia Wa
quick answers,
#1 They are heavier than a 302 just run aluminum parts to equalize the weight difference.
#2 Battery can stay in its present location just notch the battery tray so the Ac compressor will clear (real easy)
#3 Yes it will fit w/o any major cutting most of the problems are just bending/rerouting brackets,wires and hoses.
Just take your time and get all of the proper swap parts and it goes fairly easy.
GOOD LUCK
