Launching Help
  • Thread starter Thread starter foxstang9050
  • Start date Start date Aug 23, 2005
F
foxstang9050
158
El Doarado Hills, CA
Aug 23, 2005
  • Aug 23, 2005
My mustang is an automatic so i have no takeoff from the line. I have cold air, chip, headers x pipe, mufflers.... and i have no takeoff until about 3000 rpm. I need some tips on how to make my car takeoff a little faster without spendin money. Something i could just go out and do to get a Quicker launch. please help
$uperstang
476
Detroit, MI
Aug 24, 2005
  • Aug 24, 2005
Nothing without spending money, dude! Money is the key to everything! You need 3:73 or 4:10 gears and a new stall converter
F
foxstang9050
158
Aug 24, 2005
  • Aug 24, 2005
I have 3:55's but i havent installed them yet... anybody have good instruction on installing gears... or does anybody know how much it usually costs to get gears installed?
WantaGT
336
ohio
Aug 25, 2005
  • Aug 25, 2005
personally I would dump the 3.55's and go a little lower. AOD's need all the help they can get out of the hole. I have 3.90's on order right now that should be good. a nice set of lower gears could be worth up to a full second in ET. My old hatch went from 15.8 to 14.7 with just the gear swap.
QDRHRSE
1,590
Palmdale, CA
Aug 25, 2005
  • Aug 25, 2005
Without buying anything fp, timing, and weight are pretty much the only things you can change to improve your launch. Anything to free up power will help. Gears will really help. They should cost 200 or less to install.
F
foxstang9050
158
Aug 26, 2005
  • Aug 26, 2005
Would setting the idle higher help? Does anybody know how hard it is to install gears? Ive done every modification and install to my car myself, so i wanna do the gears myself but i heard their pretty tough. Off the subject, but what exactly do injectors do? Will they add very much horsepower? And does anybody know anything about the Venom 400? Supposedly it adds up to 25% horsepower and lots of low end torqu but im pretty skeptical about it
Euphoric306
905
  • Aug 26, 2005
know nothing about the venom 400 but bigger injectors are needed when youve got more air flowing through your engine... i.e. bigger maf, throttle body, aftermarket/ported intake/exhaust, bigger heads, a supercharger, etc. because with more air you need more fuel to keep up that a/f ratio and the stock injectors simpy cant flow enough fuel to meet demand
so in short on a stock engine, no, bigger injectors will do nothing for performance or might even hinder it, but with a few air flow mods they definitely will make all the difference
P
Polter83
74
  • Aug 26, 2005
The venom 400 is a flasher or chip of some sort, right?
Dont waste that amount of money.. im guessing its around 400bucks. Spend that on the gears and install. And get a converter so that the gears actually work with the transmission. That right there would be a night and day difference.. comparily to adding a blower..the night and day difference.
rsw007
469
Lexington,SC
Aug 26, 2005
  • Aug 26, 2005
converter,gears,valvebody/shiftkit
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
