Launching on slicks
  • Thread starter Thread starter rafelos1337
  • Start date Start date Aug 12, 2005
rafelos1337
20
Clovis, NM
Aug 12, 2005
  • Aug 12, 2005
Well I have about 450 hp and i was wondering what i need to have to launch hard on my mickeys 26x10s. I dont want to break a c-clip or anything. can i launch on them at idle with a stock rear end and be ok? I have really bald nitto 555s and i can spin them through half of 3rd. how good are drag radials. I was thinking about getting gforce t/a drag radials but i heard they only improve the 60 foot 2 thenths of a second. I had a 2.2 60 the last time i ran that the track before the supercharger. I would like to see it somewhere around 1.6 or something. I would like to hear peoples opinion on this thanks.
Blk91stang
607
North Brunswick, NJ
Aug 12, 2005
  • Aug 12, 2005
Assuming you have stock 28-spline axles, slicks will twist them right in half at your horsepower level . At the very LEAST, pick up some 28-spline Mosiers with the stock posi and you will be OK but the best setup would be 31-Spline axles with a spool, locker, or good posi. This is also a good time to get your torque boxes and axles tubes welded so they don't start ripping apart. Do you have subframe connectors?
rd
3,316
63
109
Ocean Springs MS
Aug 12, 2005
  • Aug 12, 2005
You have some cushion left to use up.
I have a couple dozen runs on BFG Drag Radials on my 7.5 in axle with nitrous. I have run 1.8 to 1.9 sixty foots and as quick as 7.80 or so in the eighth. It has an SVO traction lok, stock 1980 28 spline c clip axles, etc....
I have subframe connectors, boxed upper and lower control arms, and still have the rubber bushings in there. This is with an automatic car.
With some testing, you should be able to safely get the sixty foots down to the 1.8 range.
All that said, I have an 8.8 already set up, and am planning on welding up the torque boxes, and getting 31 spline stuff as soon as possible.
rafelos1337
20
Clovis, NM
Aug 12, 2005
  • Aug 12, 2005
I have sub frames. I have 3.55s in the back and a posi cause i need them both spinning for the burnouts.
maverick0716
3,924
Chilliwack, BC, Canada
Aug 12, 2005
  • Aug 12, 2005
If it were mine, I'd definitly upgrade to 31 spline hardened axles and an aftermarket posi carrier...450 rwhp is nothing to mess around with.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
First gear is too tall. Should I make it taller? Nitrous guys, help!
  • FastDriver
  • Dec 30, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 31, 2023
AeroCoupe
what would you do? sell the project and buy completed or finish project?
  • STANG32
  • Feb 8, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 16, 2025
rusty428cj
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
