launching on street tires??
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
ok so tomorrow i am getting new tires. My DRs are bald and are getting bad, i dont want to risk anything, if i take them to the track i will be burning all the rubber off and might not make it home.
so i decided to get some regular old tires.
my DRs are 255/50s
the tires i plan to buy are 225/60s quite a bit skinnier. reason i am getting this size is so i can rotate my current fronts to back and put the new ones on front, will let me rotate tires also.
so my questions are...
should i do a burnout with street tires, or just a dry hop to get loose dirt off?
will lauching on them just require more feathering so they hook up??
sucks though, i was really wanting to get to try out these DRs, but i am not going to risk anything.
Honestly, unless you are trying to run at the track for fun or to get a baseline on what kind of improvements you are making while keeping the street tires as a controlled variable, I wouldn't even bother racing on them. Buddy of mine went from 14.4 to 13.5 simply switching to nitto drag radials and a good burnout from regular street tires.
If you want to see what the car is really capable of you'll need to get traction, unless you are just looking for MPH. I used to run street tires at the track and since I tried slicks I will never go back to street tires again, the difference is like night and day. Keep the street tires for the street and get a cheap set of rims to mount some slicks on. I bought some e.t. streets 26*10.5 already mounted on stock mustang V6 wheels, barely used for $200 on ebay.
Drag radials are a joke if you plan to drive them on the street, they wear out too fast and cost too much.
how far do you have to go to your track??
if you only maybe do one run on them maybe there will be enough to get you back home.....maybe have a tire shop look at your dr's......they could maybe tell you how much is left.......cuz the last thing i'd do is tell someone to drive on questionable tires:nono: if nothing else maybe post some good pics of them someone in here could tell you im sure...
are you goin by yourself?? i was gonna say if anyone else is going with you and they had a car maybe you could scrounge up some rims and have some one take two extra tires with in case you get stuck......
then again.....depending on the shape of that t-5 you have launching on slicks might finish it if it's having issues.....either way........you'll beat your old time if everything holds up..........good luck......by the way...........i wouldn't worry about being able to rotate your tires.........as much fun as you been having in your car once their on the rear they'll never end up on the front they'll be toast.......:D
well they just went bald a couple days ago. So you think there is still some rubber left?? you can still see some of the tread lines.
i think i may go easy on them until sunday and beat the crap out of them. get new tires the day after.
so can someone give me an idea of how these thing will hook up??
will i be able to dump it at say 3k and stand on it without spinning?
kinda hard to fathom as they are just like street tires on the street. no reason to really heat em up....
i'll see what happens.
Lower the air pressure (anywhere from 12-20 psi, the highest you can run with them still hooking) do a good 5-10 second burnout, and me personally I let the tires pull me out of the burnout (just a little as they start to grab). I personally wouldnt just dump the clutch on a car with a stock suspension, but would stick it at 3500 or so and ride the clutch out some. I dont have a lot of DR experience, but from what I have head unless your car is set up right, dumping the clutch will result in bad tire spin!
Try a few techniques, and as a referance, anything under 2.0 your doing alright, and anything in the 1.8 range your doing pretty good! If you could hit a 1.7 on some DRs, thats hooking well!
