Lawyer's 88 'vert
  • Thread starter Thread starter RacerJames
  • Start date Start date Aug 17, 2014
RacerJames
165
23
39
Kingman AZ
Aug 17, 2014
  • Aug 17, 2014
Been doing some research fo my Lawyer buddie's car. Its a 2.3 auto right now, and over the past 8 years or so he has put two short blocks in it because the passenger side of the block has broken off twice, and he's replaced the trans once, because the bellhousing cracked in the same location. I have an MFI 3.8 and AOD from a 90 T bird. We are considering this swap because the engine and trans in the car are both broken again. Our aim is to build in reliability, and actually, better mileage, with the v6. Better performance would be a plus, but not part of the main goal. This is NOT a sportscar, and we have no illusions of winning stoplight races. We live in the desert, where roads are long and straight for 50 miles at a stretch. No plans for canyon carving, never gonna see a racetrack of any kind. It's a cruiser, period.
I was at the "used parts buffet" recently, and came across a 94 with a v6 and t5. Having researched the t5, I see that in 94 they deepened the bell housing to locate the shifter in the then new body.
My questions are these:
What might be causing the 2.3 and trans to be breaking, and, will our planned redesign fix this?
And, if we choose to go with the t5 from the 94, would relocating the engine forward 5/8 inch put the shifter back where it needs to be in the 88?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Aug 17, 2014
  • Aug 17, 2014
It's only 5/8 of an inch farther back. You probably wouldn't even notice the difference. If anything it would put the shifter in a more comfortable location with the engine in the factory position. I couldn't answer the other questions.
Kurt
RacerJames
165
23
39
Kingman AZ
Oct 10, 2015
  • Oct 10, 2015
We decided to go with the AOD after all. The install is going ok. Might need some help with wiring issues. Anyone here ever do this swap, and what issues/solutions did you have?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 10, 2015
  • Oct 10, 2015
You are going to need the computer wiring harness and computer from the 95. Since the 86-93 AOD doesn't have any connection to the computer you'll need the 94- 95 V6/T5 version of the wiring harness and computer. The 94- 95 AODE computer would keep spitting codes because it didn't have a transmission that it could talk to.
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
NEW MEMBER, Big block in a fox
  • 88 BBFOX
  • Aug 17, 2020
  • The Welcome Wagon
2K
The Welcome Wagon Oct 31, 2020
Werecow91
W
Fox '88 GT Vert engine swap
  • cameronc77
  • Jun 12, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 13, 2019
cameronc77
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
74K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
