  • 1994 - 1995 Specific Tech
LC-1 Wiring Plan..thoughts?
  • Thread starter Thread starter vyal
  • Start date Start date Jul 23, 2006
V
vyal
38
  • Jul 23, 2006
Here is my plan. I think i have it all squared away but i would be thankful for any input. I'm going to use to LC-1s to emulate narrowband and run the info to a Dataq and tweecer
Power -> From the original O2 harness (Grey/Yellow)
Analog to ECU -> Original wire from o2 harness (Red/Black & Grey/Lt Blue)
Analog Ground -> Pin 26 (Ground reference for sensors)
My question now are where to run the system ground and the heater ground. Can i run the system ground to pin 26 as well? Where does the EEC actually ground to, as in, where exactly is the bolt that it goes to? I know the heater ground has to be within a certain voltage range of the system ground. If the grounds have to be within a certain range im leaning away from using the ground wire in the o2 sensor harness. Any thoughts?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 23, 2006
  • Jul 23, 2006
why not just get an extra bung welded in?
WhiteDevil
2,717
San Diego
Jul 23, 2006
  • Jul 23, 2006
Thats what im going to do. I have a PLX-300 going in with my 347. But make sure you let us know how it works out because if it works good i might consider doing this myself. Also using a DataQ hook up for you wide band is that like an empty wire in the wireing harness? I want to be able to data log my wideband but i dont want to wire it to my EGR because i need my EGR for smog. keep us posted.
V
vyal
38
  • Jul 23, 2006
Why have 4 sensors floating around when only 2 are going to be used if i dont need to?
WhiteDevil, go to www.dataq.com. The DI-194RS (~$30) is what you run your wideband analog to. You only need one of these if you want to run your wideband to you Tweecer without using the EGR. Dataq can log any parameters you want that put out a standard voltage signal. Dataq is the only way to interface your wideband to your tweecer without going through EGR. Hopefully it should all work flawlessly
mootang
907
texas
Jul 24, 2006
  • Jul 24, 2006
here is a couple links that should help! you don't have the but they do discuss the data Q and all the rest of the hook up
http://eectuning.org/forums/viewtopic.php?t=5429
http://eectuning.org/forums/viewtopic.php?t=6352&highlight=lc1
If you have anymore questions I will try and answer them when i get home from work.
urban96
3,464
Syracuse, NY
Jul 24, 2006
  • Jul 24, 2006
your going to run a wideband on each bank? i can see your point of wanting to just keep it more simple but thats a lot of wiring and i wouldnt want to send too much voltage to the wrong wire and fry something
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 24, 2006
  • Jul 24, 2006
Some say it is best to keep stock oem system undisturbed
It goes without saying, that method requires bung or bungs installation, if you wish to collect data from either side to be installed.
You can do the egr or data Q thing.
I did the egr, bung on each LT collector method for the most options.
I got my egr pcm input on a switch for easy either or selection
Good Luck with your wb install
Grady
V
vyal
38
  • Jul 24, 2006
I based alot of my thought off postings from those forums, though im not sure they guy on the first one understood the wiring. I guess i just need to know where exactly the EEC grounds to and i can run wires to that area. Anyone know where that is or do i need to start tracing wires?
Stanger007
2,015
Baton Rouge, LA
Jul 24, 2006
  • Jul 24, 2006
Here's how I installed my LC-1 to DataQ to USB to twEECer.
I just had a 3rd bung welded on and left my stock O2 sensors in place.
Feel free to ask if you have any questions.
V
vyal
38
#10
  • Jul 25, 2006
  • #10
i replyed back on your other post... tks for the info...b
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
  • dan50
  • Jul 18, 2026
dan50
L
2004 Mustang Oxygen (O2) Sensor Issue
  • letumeternum
  • Dec 30, 2024
Lexiii12
L
