  • SN95 4.6L Mustang Tech
LCA's any good?
  • Thread starter Thread starter steveb24
  • Start date Start date Feb 22, 2006
steveb24
555
wilmington, DE
Feb 22, 2006
  • Feb 22, 2006
http://cgi.ebay.com/ebaymotors/1979...ewItemQQcategoryZ33583QQitemZ8040357899QQrdZ1
as im doing suspension right now..im tryin to decide on which control arm to get..while spending the least i can..w/o sacrificing quality..how are these ones?? also..are upper control arms needed? if i got a good set of lca's, would uppers be necessary? thanks
trailblazr81
571
Hollister, Cali
Feb 22, 2006
  • Feb 22, 2006
Is this for street, drag, or road race use? The solid end could be harsh on a DD. The lowers make more of a difference than uppers. I have lowers with poly bushings on each end since its my DD.
steveb24
555
wilmington, DE
Feb 22, 2006
  • Feb 22, 2006
well it says they have been used for cars with over 700 hp..so its probably street and track..how are yours with the poly bushings? im looking at getting some control arms..and although the mac ones dont seem popular..they look just the same and the price is right.
hognutz
1,940
albany, oregon
Feb 22, 2006
  • Feb 22, 2006
I have the MM drag arms. the are spherical bearing front and rear.
those arms are mild steel. I would not get them
propellerhead
1,541
"but what's with the but shots?"
Feb 22, 2006
  • Feb 22, 2006
I plan on getting these when the time comes.
http://www.uprproducts.com/shopping/shopexd.asp?id=225
I don't want to spend $300 on Global West or $260 on MM lowers, then more later for uppers. The stiffer arm will be so much better than stock arms. The polyurethane bushings will be so much better than the factory rubber bushings. I think I'll be happy with these without spending a whole lot of money on overkill.
J
Justin03GT
199
Mount Pleasant, SC
Feb 22, 2006
  • Feb 22, 2006
you didnt go wrong with the UPRs..i have them and love them, they do transmit more road noise and some vibrations more than stock, but the added bite more than makes up for the minimal comfort decline.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Feb 22, 2006
  • Feb 22, 2006
I have also been looking at the UPR Products LCA's, but I'm not sure if I wanna go with UCA's as well.
Will you get the added vibrations/noise with just the LCA's or does that mainly come with UCA's?
steveb24
555
wilmington, DE
Feb 22, 2006
  • Feb 22, 2006
how about getting just pro3 street/race lca's..they look pretty good
hognutz
1,940
albany, oregon
Feb 22, 2006
  • Feb 22, 2006
vibration would be dependant on bushing design.
I don't have any vibration issues just a bit of road noise and that is solid spherical bearings. the preformance is so much better than poly arms though.
I think the thing people don't often understand about control arms is uppers hurt your handling. poly bushings in your upper arms produce bind. If you get UPR uppers you car will not handle as well through the curves and just the right lower arm. there is a reason companies like MM, griggs, global west don't make uppers.
If you are not launching your car on slicks you don't need uppers. you will not get enough traction need that kind of control of the axle IMO.
propellerhead
1,541
Feb 22, 2006
#10
  • Feb 22, 2006
  • #10
Interesting... Can you explain more about the uppers and how they affect handling, ride comfort and launching?
jasonh_86
I
May 20, 2005
1,156
Arkansas
Feb 22, 2006
#11
  • Feb 22, 2006
  • #11
+1
Not callin bs, I just don't know a whole awful lot about the UCA's
trailblazr81
571
Hollister, Cali
Feb 22, 2006
#12
  • Feb 22, 2006
  • #12
Read this about uppers n lowers http://www.miracerros.com/mustang/t_suspension.htm#Rear
jasonh_86
I
May 20, 2005
1,156
Arkansas
Feb 22, 2006
#13
  • Feb 22, 2006
  • #13
Nice Link!
propellerhead
1,541
Feb 22, 2006
#14
  • Feb 22, 2006
  • #14
I wish they'd expand on the section about control arms. Like make a two page thing on it.
san~man
O-G
A little grass shack on a big lava rock
Feb 22, 2006
#15
  • Feb 22, 2006
  • #15
You need to first decide what your goal is. If it's mainly drag racing (ie going in a straight line), poly bushings are fine.
However, if you want to corner and stuff, poly on both sides isn't the way to go. MM's site has some good reading on that topic, but you will basically get MORE bind in a corner with poly/hard bushings on both sides versus spherical/poly or even the stock rubber for that fact.
The reading is here:
http://maximummotorsports.com/rlca.asp
G
gotchopsticks
315
#16
  • Feb 22, 2006
  • #16
are the UPR adjustable control arms any good for drag racing? how about when added with coil overs and G-Force t/a's?
steveb24
555
wilmington, DE
Feb 23, 2006
#17
  • Feb 23, 2006
  • #17
basically..they would be for racing..but i dont race too often. im gonna order the pro3 street/race lca's and that will be all for that department.
J
Justin03GT
199
Mount Pleasant, SC
Feb 23, 2006
#18
  • Feb 23, 2006
  • #18
i went with upper and lowers because there just arent any curvy roads where i live...the roads are flat and straight, no need to have a super handler when the most corner carving i do is making right and left turns onto other roads
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Noisy LCA
  • crazyone64
  • Aug 1, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 2, 2025
manicmechanic007
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
