  • SN95 4.6L Mustang Tech
Leak
  • Thread starter Thread starter jrc_03_gt
  • Start date Start date Dec 1, 2004
jrc_03_gt
786
  • Dec 1, 2004
Anyone have problems with the rearend leaking after a gear swap? I had a swap done and Its leaking slowly. Someone told me that the newer stangs dont have a gasket just some kind of silicone to seal the housing. When did they quit using the gaskets? I have a 2003 gt. I think Im going to have a gasket put in there.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 1, 2004
  • Dec 1, 2004
it is a silicone sealer, you have to weave it around the bolt holes. so buy some and apply it this time!
jrc_03_gt
786
  • Dec 1, 2004
It was done at a dealership. Now they want to put in a gasket in it.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 1, 2004
  • Dec 1, 2004
they sealed it up wrong, good luck
jrc_03_gt
786
  • Dec 1, 2004
How can you seal it up wrong?
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 1, 2004
  • Dec 1, 2004
dunno, guy probably dabbed it on wrong or was making to big of a swirl with the silicone.
jrc_03_gt
786
  • Dec 1, 2004
I hope the gasket works . This will be the 2nd time they tried to fix the leak.
Could the cover have been overtightened? I dont know how thick that cover is maybe it is crimped now and does not fit how it should. Does anyone know how thick the cover is? Should I get an aftermarket cover for the rearend from jegs?
jrc_03_gt
786
  • Dec 1, 2004
I think it is leaking where the driveshaft slips into the rearend. Is there a gasket there or is that just a sealant?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 1, 2004
  • Dec 1, 2004
for the pinion seal, there is a seal there, kind of like a gasket but different. i believe Fel-Pro and Victor-Reinz make gaskets to replace the silicone sealant for the cover.
1990BLUEGT
85
S. CALI
Dec 1, 2004
#10
  • Dec 1, 2004
  • #10
my diff started leaking at around 7,000 miles. just buy the silicon from the dealership (don't forget to buy the limited slip additive and gear oil while your there). take off the cover yourself then scrape off the old silicon using a razor blade. then set the cover on a flat surface and check to see that are no spots where it bends up. then what you want to do if scrape the old silicon off the diff. itself. clean everything really well and apply the silicon (use a lot, but not all of it) to the cover. then bolt on the cover to the diff. try to use a sequence like that of tightening a tire. don't forget to add that limited slip additive.
i did this myself because i didn't want the dealership to add any "hard" miles to my car. dealership porters know what i'm talking about.
my 2001 gt now has 35,000 miles on it without a leak.
whhooops i didn't see the last two posts, but go down there and check. it's most likely the differential cover. it's easier than you might think.
Blev
1,295
So. Cal. V-Town
Dec 1, 2004
#11
  • Dec 1, 2004
  • #11
I have a 98 and the same problem. Had my gears done and after a few K it started to leak
jrc_03_gt
786
#12
  • Dec 2, 2004
  • #12
Again I think its up by the driveshaft and then blowing back. If so did someone say there is a pinion seal? How involved is that to fix. Is it fixable in a hour or two? Thanks for the info.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 2, 2004
#13
  • Dec 2, 2004
  • #13
there are 2 ways to do it, theres the correct way, and the way everyone does it. the way everyone does it involves taking off teh driveshaft and punching the nut and flange with a punch and taking the nut off, then replacing the seal and putting the nut back on and tightening it about 1/16th of an inch past the mark. the correct way involves taking the pinion gear out replacing the crush sleeve and then resetting pinion depth and replacing the seal.
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
