Leaking a crap load of oil!!!!
Guero
2,148
My car aint sucking oil no more. But it is leaking alot of it!!!!!!! And i cant see were its coming from. Almost the whole bottom of the car is oiled!!!! So i cant tell!!!!!!! Is there like a dye i can put on there or something? Its pissed me of cuz i rather fix this than tune it, and i was gonna get it tuned this Saturday:mad: :bang:
Make sure your catch can stuff is all clear and free. If it clogs up, you'll start pushing oil out the seals.
Given how new all that catch can stuff is, I'd really check things over.
Good luck bud.
get a light and look for the highest point the oil is leaking from. Oil will flow down and not up so look for were it starts that way.
Is it under the car? on the back of the motor? front? one side or the other?
Start with the front and back intake area. Then look at the valve covers. Work your way down to the timing cover. Then go around the main seals on the front (if its on the back it will be coming from up under were the trans mounts to the motor...its kinda up hill there so its will stick out. Lastly the pan gasket and drain plugs (a bad drain plug gasket will leak like a mother).
Is the last 2 post serious??
Seems like its the Valve cover Gaskets. Im gonna order new ones. And its not the catch can!!!
I also just washed the whole bottom so ill defitnately know. If its the V/C thats an easy fix.
Uhh .... yeah. Take off the oil cap (a.k.a. 710 cap) and look down in the oil spout into the valve cover. You will see the canooder valve very easily.
EDIT: I can't take it anymore. Just messin' with ya' man. Besides, I don't want to be responsible for what happens when you don't see it. It's hard telling what you might do, lol. I have used that one in person with a kid in HS. Funniest thing ever!
A few years ago me and a friend were with riding in another friends car. We had already planned this out. I was riding shotgun and said "Man whats that noise" Then my buddy said that we should pull over. So we did, me and him checked it, started pointing at random **** and making gross faces. Then I told him, "Well I got some good news and some bad news. Its not gonna run much longer, but we can make it to autozone. You need to change your double sippie cups. They are like 2 dollars. So lets go and ill change them in the parking lot." He got out of the car and I told him Id take the old ones off while he went get the new ones. As soon as he went in I closed the hood and went sit down. He got in the car and said "**** you guys" then we all started laughing and went home.
I cant beleive he told them he needed new double sippie cups. :rlaugh:
If you get VC gaskets and Ford style gaskets fit for you, I'd get the rubber over metal versions. Very nice pieces.
I didnt literally mean the catch can filling up or clogging. I meant to ensure there are no kinks in the rubber lines to and from them. Any kink can create a lot of issues.
Good luck.
Guero said:
on mine it was coming out there and running down the side of the block and all over
