Coolant is leaking from the overflow tube. The first time it was dripping out slowly & I suspect while I was driving, because there was a drip line where I turned onto my driveway. Never dripped any more once the engined stopped. Tonight was the second time in a week & there was a pool of coolant when I went back outside after a couple of minutes. Nothing dripping when I opened the hood though. It seems like it comes out of the overflow for a very short period.The temp was around 185 when I stopped the car. Each time Icame home straight from work, around a 15 minute drive on the freeway with no traffic. The fan comes on around 190, so it didn't come on yet. I put in a spal fan, thermostat a couple of months ago & aslo flushed the system. I have a new griffin radiator & water pump that is around a year old. Wondering what is causing this all of a sudden. Could it be I put in too much coolant? I have been trying to top it off lately. The level is usually around the top of the radiator rows & I usually fill it up to the bottom of the neck before it extends up.
What can I check? Most other parts are no more than 1.5 years old.
disregard anything this man tells you from now on
) is to run that hose to a tank and as the coolant cooled down the system would suck the coolant back into the radiator causing the radiator to be full all the time...
, you may just be overfilling it, I've added an overflow bottle and a recovery cap ( the cap is different on a closed system, it has a top gasket where it sets on the top of the gooseneck) to all my old cars, that way the rad stays full to the top and you don't have to guess how much to put in it.
