leaking coolant
  • Thread starter Thread starter twisted88
  • Start date Start date Oct 13, 2004
T
twisted88
southern jersey
Oct 13, 2004
  • Oct 13, 2004
after getting my car put together after two years of slowly fixing it i filled up the radiator. a couple seconds later i can hear it leaking out across the floor. it was coming out somewhere above the starter (passenger side). is there anywhere that u guys know of on that side that it might be easily fixed to stop this leak?. i'm just hoping the water jacket didn't crack or sumthing from winter last year. thanks
D
Daggar
3,902
  • Oct 13, 2004
Double and triple check that all of the sensors and fittings plugged and screwed into the lower intake. Check the timing cover for leaks as well. Both are notorious for suprises. For me, it was the fitting that goes into the lower intake then up to the TB spacer. Drove me nuts because I couldn't see it with everything together. That ran down the back of the block. In your case... I'll guess that it's your timing cover not completely sealed. Just a guess.
T
twisted88
southern jersey
Oct 13, 2004
  • Oct 13, 2004
repair
if that is the problem what would be involved to fix that? change agasket or just tighten it down or what? thanks
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
