Ok, i've tried different ways to install my trans pan gasket and it leaks every time. What are the tricks tips to getting one sealed up correctly? I've tried one with sealant/RTV, one dry, and one with vaseline on the gasket to hold the gasket in place. Any ideas on what i am doing wrong? The only gasket i can find is a standard cork one without the steel inserts, so i'm trying not to overtorque the bolts. I use a nutdriver so i won't overtorque them. I've got another leak and would like your suggestion. I have a leak coming from between the main case and the tailshaft housing. There doesn't seem to be any kind of gasket on there and can't locate one. Should i use gasket maker on it? Kinda worried using gasket maker on auto trans cause i don't want to plug anything up. Other leaks include the dipstick tube and rear seal, but those are easy ones. I think the only place it doesn't leak is the shifter shaft
Thank goodness. Let me know your tricks and suggestions!!!
