leaky stang :(
lucky bagels
hey any1 no where all the freeze plugs are on a 89 lx 302? im leaking anti freeze from somewhere and i cant figure out from where. i check the two hoses on the rad. and the two for heat there all fine.
if anyopne nos of any more hoses to check or where the freeze plugs are thanks a lot
Same problem here. I just changed the T-stat on the '86 a month or so ago. Either I didn't seat things right, or I didn't quite get all the old gasket crap off there, but it took me awhile to figure out that it's leaking from the thermostat housing.
Two bolts, two hose clamps, some blue RTV silicone, a cheap gasket, and a little bit of antifreeze will fix that. :nice:
My bet is its the overflow bottle itself. My bottle has a crack in it that can't be seen unless its taken out and its empty almost all of the time. You should be ok as long as you have constant freeze in the radiator and aren't overheating. If you are overheating its more than likely a hose if you aren't I put my money on the overflow leaking. Mine drains quick when I fill it and the crack is extremely small.
Heya Dark... My fail-safe fix for this is to seat the t-stat in the housing then hold it in place with two tiny dots of superglue.
It beats the string method, hands down.
its not the water pump i check it. i poor water into the water pump and it goes in then after about 1/4 of a gallon and a few seconds it leaks out, on the drivers side. the only water i see is underneath, and its running down the oil pan...thanks for all the tips, and please keep them coming .
Freeze plugs are located in the side of the block. See if you see anything leaking around them. There is a chance that you actually have a headgasket failure that is allowing coolant to leak out between the heads and the block. Did you have an overheating problem before this all came about?
The only reason a freeze plug should "leak" is because you had a low amount of anti-freeze in your system, the water froze, and pushed the plug out.
well i had half water half aint-freeze then the weather dropped real quick. a day or two later i noticed it...its not a head gasket, there not anti-freeze in the oil. do i have to take my headers off to get to the freeze plugs?
I don't know if someone mentioned it, but have you checked the egr hoses? More specifically, the hose leading towards the firewall side of the manifold. When that small hose went bad I went crazy looking for the leak. It's not easy to spot because there's so much clutter behind the manifold. The water tends to puddle towards the back of the engine which also makes it harder to locate the source.
ill advised- do i have to take the upper manifold off to get to this hose?
No, just follow the small hose leading from the left side of the t-body (I'm assuming you haven't bypassed your egr) and you'll see where it leads: next to the heater hoses on the firewall side. I developed a leak right at the base of the manifold where the hose had dry-rotted. It's not easy to reach back there but you definitley don't need to pull the upper.
#52 on the diagram.
http://www.cjponyparts.com/NewTechFBengine.aspx
