Lean + code 66 after "hot-pluggin" MAF
  • Thread starter Thread starter Booksix
  • Start date Start date May 15, 2007
Booksix
179
San Diego, CA
May 15, 2007
  • May 15, 2007
Did a few things on my car (which included removing the maf) and when I first fired it back up it was idling funny and I realized I forgot to plug the MAF back in. So I had someone do it for me but I think plugging it in while the key was on/enging running may have fried it some how.
I now run mega lean (according to my air/fuel ratio gauge) and after driving for about 20-30 minutes I get a CEL and pull 41 - running lean and 66 - maf signal low. Did I fry it? How can I test the MAF itself?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 15, 2007
  • May 15, 2007
Clear the codes from the computer by disconnecting the negative battery terminal for 20 minutes or so. Then Re-test and see what you get.
IF you get code 66 again, here's some help.
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and ground. Make your measurement with the MAF disconnected from the wiring harness.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Fuse panel layout
Vacuum routing
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
stang&2Birds
2,091
New England. :-) CT/MA
May 15, 2007
  • May 15, 2007
You may have fried the MAF, the EEC, or both.
You should ever hot plug any electronics unless it's made for that (like USB).
Here's the reason, when you connect a NON hot-plug designed connector, you have *no idea* which pins are going to connect in what order! So, the following may happen:
o Power connects first
o Signal connects second.
The Power now goes through the signal pins of the chip to try to power up the chip.
In your case, this could have ruined the chip on the MAF or the EEC. The chip on the MAF would have 12V going from the 12V line through chips signal lines. On the EEC, that chip would be trying to sink a lot more current than it was designed for. The result is that *all* of the chips _could_ be fried. When one chip goes, it's pins may do "bad things" that can do more bad things to other chips. And so on.
In reality, often, only one dies "first". But, the chip on the other end has been stressed! And the reliability of the chip is very questionable.
Of course, this does not happen "every time". A lot depends on the contact sequence and the time difference in the contacts mating.
Bet you didn't know that there was someone involved with hot swapping when it was in it's infancy on this forum. Yea, Future Bus!
Booksix
179
San Diego, CA
May 15, 2007
  • May 15, 2007
Thanks guys! I should have known better being that I work with this stuff and computers all the time...
I just kinda shouted out "we didn't plug the mass air meter in!" and before I could process it he had it done! LOL, guess it's test time... thanks.
Booksix
179
San Diego, CA
Jun 1, 2007
  • Jun 1, 2007
Ok, so I got my new MAF in and no longer get a code for that... but for some reason I still get 41 (which I did NOT get 3 hours before refiring when I removed it to tighten header bolts)... But from your description, jrichker, it means the SYSTEM is lean, but the car would probably RUN rich due to over compensation but it's not... it's running so lean it barely registers on my air/fuel ratio gauge... any ideas... I know my O2 sensors are plugged in and the were fine one minute and possibly shot the next...?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 1, 2007
  • Jun 1, 2007
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
