Lean, Or Rich?
  • Thread starter Thread starter louieb
  • Start date Start date Sep 20, 2012
First Prev 2 of 2
L
louieb
70
#21
  • Sep 21, 2012
  • #21
it has a 92 a9l CPU not much better, but i was lucky to get it. it runs good now. I just changed to a 195 themastat the other day. I had 180 degree stat before. to low with aluminum heads. warms up nice now.. some idle surging very touchy throttle response.
fuel economy is bad, and there is hp being wasted.. cheers.
Admin Dude
Jan 4, 1985
42,933
21,109
234
Box behind Walmart
Sep 22, 2012
#22
  • Sep 22, 2012
  • #22
louieb said:
thanks for this link. i guess i need to be tracing, off the fuel pump relay.
also i would like to add, these red bosh injectors flow 30 lb at 42 1/2 lbs. the motor seems to like more fuel. it was originally set at 36 lbs from performance shop. they said thats normally what they set them at. when i changed it the motor was much better, but already i had the pip sensor in the distributor starting to fail or was not doing its job. after a year or so it finaly quit all together. (pip sensor)
I just hope i can find this bad ground wire.
Good luck with your hunt. I know what it's like chasing gremlins. jrichker actually provide the link to the diagram above. All I did was post it as an image. Have you pulled, and are you getting a codes from the EEC?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 22, 2012
#23
  • Sep 22, 2012
  • #23
Noobz347 said:
No... because the slope in the EEC is for a 19 lb injectors. A MAF can you close but it can't tell the EEC how to behave across it's entire duty cycle. So you'd be fat at some portions of the table and lean in others. The EEC doesn't know it's not trimming a 19.
30's are generally the limit without a tune. Yeah.... I've seen folks go larger and be really lucky (or least claim that they were)... I've not been that lucky. lol I've had to trim everything over a 24 on a non-Cobra EEC.
So how does Pro-M get their meters to work so well. Especially in comparison to competitors like C&L?
Admin Dude
Jan 4, 1985
42,933
21,109
234
Box behind Walmart
Sep 22, 2012
#24
  • Sep 22, 2012
  • #24
Pro-M meters are known for being very exact. They don't drift, and their resolution at all power settings is really high. In other words: They're accurate as hell. I've not known them for being any better than anyone else for matching large injectors to a stock, un-tuned EEC though. They are however, known for measuring air mass extremely well where C&L meter housings can be hit or miss.
L
louieb
70
#25
  • Sep 22, 2012
  • #25
thanks fot the diagrams. i think it is the same as the 92.
the scanner called fuel pump open secondary circuit.
any one now were to look for secondary? ty
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,811
234
Dublin GA
Sep 22, 2012
#26
  • Sep 22, 2012
  • #26
What was the exact code you got?
L
louieb
70
#27
  • Sep 22, 2012
  • #27
jrichker said:
What was the exact code you got?The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). Notice that
pin 19 on the computer is the monitor to make sure the pump has power.
The fuel pump has a black wire that supplies the ground to complete the circuit.
no codes just open secondary fuel pump. used a scanner tool not a ob1?
i think i found another one of your posts on fuel pumps and relays. good stuff there. I think it may be the pink wire under the seat i need to find. i think thats what was described as secondary to ground..
my question is how many wires go to starter relay? should any wires be under the seat?
do these wires run along the fender wall to the front of the engine? I may have a break in trunk. is this correct? one other possibility, big daddy forgot to hook it up when installing mass air? hmmmm... i may have broke a red striped thin wire?
were should i be looking?
L
louieb
70
#28
  • Sep 23, 2012
  • #28
i found this post here on fuel pump connection, and relays.
http://www.stangnet.com/mustang-forums/threads/help-fuel-pump-relay.844853/
jrichker
Mar 10, 2000
27,512
2,811
234
Dublin GA
Sep 23, 2012
#29
  • Sep 23, 2012
  • #29
I
The idea is correct, but the wiring is different on 91 and later cars. The inertia switch is in line with the fuel pump instead of the fuel pump relay coil.
Here's the test path of 91-93 cars...
Fuel Pump Troubleshooting for 91-93 Mustangs
Revised 19_Apr-2012 to update change of fuel pump runtime in crank mode
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 2-5 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the upper RH corner to ground.
If the fuse links are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump Relay:
On 91 cars, it is located under the driver's seat.
On 92 and 93 cars it is located under the MAF. Be careful not to confuse it with the A/C WOT cutoff relay which is in the same area. See the diagram to help identify the fuel pump relay wiring colors.
Be sure to closely check the condition of the relay, wiring & socket for corrosion and damage.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
Theory of operation:
Read this section through several times. If you understand the theory of operation, this will be much easier to troubleshoot. Refer to the diagram below frequently.
Diagram of the fuel pump wiring for 91-93 cars.
path.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The control path consists of the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the relay coil and then from the relay coil to the computer (light blue\orange wire). The computer provides the ground path to
complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (pink/black wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows
through the pink/black wire to the contacts and through the dark green\yellow wire to the inertia switch. The other side of the inertia switch with the brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel pump has a black wire that supplies the ground to complete the circuit.
Power path:
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92 or later models the fuel pump relay is located under the Mass Air meter. Watch out for the WOT A/C control relay on these cars, as it is located in the same place and can easily be mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Inertia switch:
The location for the inertia switch is under the plastic for the driver's side taillight.
There should be a round plastic pop out cover over it, remove it to access the switch button.
With the test connection jumpered and ignition switch in The Run position as described above, check the brown/pink wire. It should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the dark green\yellow (inertia switch input) and brown/pink wire (inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire means the inertia switch is open.
Press on the red plunger to reset it to the closed position. Sometimes the inertia switch will be intermittent or will not pass full power. Be sure that there is 12 volts on both sides of the switch with the pump running and that the voltage drop measured across the switch is less than .75 volts.
Pump wiring: Anytime the ignition switch is in the Run position and the test point is jumpered to ground, there should be at least 12 volts present on the black/pink wire. With power off, check the pump ground: you should see less than 1 ohm between the black wire and chassis ground.
Make sure that the power is off the circuit before making any resistance checks.
If the circuit is powered up, your resistance measurements will be inaccurate.
Control path:
Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay.
No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections coming from it. The ECC relay is located on top of the computer, which is under the passenger’s side kick panel. It is not easy to get to, you must have small hands or pull the passenger side dash speaker out to access it.
Relay: The light blue/orange wire provides a ground path for the relay power. With the test connector jumpered according to the previous instructions, there should be less than .75 volts.
Use a test lamp with one side connected to battery power and the other side to the light blue/orange wire on the fuel pump relay. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. Remove the test jumper from the ECC test connector.
With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow.
No glow and the wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood. Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer and everything else is connected. Turn the ignition switch to the Run position and observe the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump the codes. Turn the ignition switch to the Run position. The light will flicker when the computer does the self test routine. A flickering light is a good computer. No flickering light is a bad computer. Remove the test jumper from the ECC test connector located under the hood.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
for help on 88-95 wiring Mustang FAQ - Engine Information
Fuel pump runs continuously:
The fuel pump relay contacts are stuck together or the light blue/orange wire has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use an ohmmeter to check out the resistance between the light blue/orange wire and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
First Prev 2 of 2
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
