leg room
  • Thread starter Thread starter steemin
  • Start date Start date Jun 6, 2005
steemin
201
Ft. Wayne Indiana
Jun 6, 2005
  • Jun 6, 2005
Just purchased a 66 Mustang FB.
I am really struggling with leg room..
I am not a "giant" 6'2" 200 lbs.
Car has a manual trans.
I need to pick up some extra space somewhere so that I can shift and drive the car aggressively.
Options?
Thanks,
Scott
TBP
681
Transient
Jun 6, 2005
  • Jun 6, 2005
Scoot the seat back? Seriously, not really sure what else you could do.
69 Capecod
97
Cape Cod MA.
Jun 6, 2005
  • Jun 6, 2005
Is the seat all the ways back if so try unbolting it and bolt it in a new locationon the tracks.
v8stang67
839
Nacogdoches, Tx
Jun 6, 2005
  • Jun 6, 2005
I saw an article once about removing the seat platform and cutting about 2 inches off the bottom and moving it back a little. This will give you some leg room and head room. However, I'm 6'7 240 and havent really had much problems with space. Maybe I just drove it for so long that I was use to it though. This project isnt too hard if you have a welder. It will give you a chance to clean up your floor pans if you havent done that already.
65fastback2+2
1,229
Louisville, KY
Jun 6, 2005
  • Jun 6, 2005
i had a 65 FB and im 6'2" never any problems.
351carlo
267
Philadelphia
Jun 6, 2005
  • Jun 6, 2005
I can understand if it's a manual and having trouble. I'm 6'3'' and have long legs, and often contemplate moving the seat back a little.... but that would require drilling hte floor pans.
There are ways to do it, but you need to consider the pros and cons. Obviously moving the tracks back a couple inches will achieve your goal.
302 coupe
1,952
Macon, Ga.
Jun 6, 2005
  • Jun 6, 2005
just sit upright in the seat. If you don't slouch, you should have plenty of room.
Also, the stock seats aren't exactly made for aggressive driving, you can and will slide out of them. Get some good seats and seat belts, then see how it feels.
steemin
201
Ft. Wayne Indiana
Jun 6, 2005
  • Jun 6, 2005
Thanks for the reply's.
Just bought the car.
The issue is not head room but rather leg room to operate the clutch,gas and brake pedal. My left knee is really tight between the steering wheel and the door panel (and the door opening lever. Ouch!).
I don't see how I can aggressively drive this car w/o some more leg room.
The car has Corbeau GTS II seats.
And a Momo 14" steering wheel.
I am putting in a flaming river tilt steering column.
I am also looking for options that would possibly lower the seat as well as give the seat a couple of more inches of travel backward..
Scott
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 6, 2005
  • Jun 6, 2005
I'm 6'4" and my '65 notch with Tempo seats put me too far into the dash, shifter(stick), and wheel. I made up some brackets that went between the rails and seat that moved the whole thing back 2". Its was only just enough, though. My '68 could use another inch as well. Another option was mentioned that involves pulling ou the carpet in order to relocate the seat mounting points on the floorpan(cutting & welding).
XXBULLETSXX
301
Kannapolis, NC
Jun 6, 2005
#10
  • Jun 6, 2005
  • #10
Ok this IS the fix. I plan on doing it once I get my welder or my neighbor let's me borrow his for a couple weeks! LOL
http://www.mustangsplus.com/tech/seat/index.html
Enjoy!
Jester67
908
TN
Jun 6, 2005
#11
  • Jun 6, 2005
  • #11
Enjoy!
You beat me to it.
I am going to be doing this in the next couple of weeks. I have to replace the floor pans and the seat perch as well so it is a great mod. I’m not that tall 5’10 but my middle age spread came early. Having said that I have the seat all the way back now. I think there is variation in the placement of the platform form car to car. Also with out the benefit of a collapsible steering column or air bags I wont as much distance between the wheel and my chest as possible.
66StangFastback
181
norman, oklahoma
Jun 6, 2005
#12
  • Jun 6, 2005
  • #12
Mine didnt come with a track so when the car was my moms (shes 4'11) her dad had to instal a sliding track under the seat so it would slide far enough forward. You might try installing one or just measuring to see if it will go far enough back for you
2nd Mustang
2,488
Southern California
Jun 6, 2005
#13
  • Jun 6, 2005
  • #13
Hijack in progress: I'm just the opposite. I'm only 5'8" and need to push the seat forward to be able to press the clutch pedal to the floor. I could drive with the seat further back, even with manual steering, but there's the clutch pedal issue. I wonder if a mod like the pedals on the car the kid drove in Indiana Jones and the Temple of Doom is possible, some kind of spacer on the pedal?
66StangFastback
181
norman, oklahoma
Jun 6, 2005
#14
  • Jun 6, 2005
  • #14
Hahaha..thats completely random. My seat has to come forward too. Im 15 and ill be getting my license in about a month and a half. Im about 5'4 or 5'5 so the seat definately has to come forward for me, but not as much as for my 4'11 mom.
XXBULLETSXX
301
Kannapolis, NC
Jun 7, 2005
#15
  • Jun 7, 2005
  • #15
Ok, don't laugh but I zip tied some 2X4 blocks of wood to the pedals on my son's Green Machine so he could reach the pedals. That worked ok for a little while but his foot would slip off every now and then so I ended up cutting off the stop that stops the seat from sliding forward. Works great now. Moral of the story is Confusious say "blocks of wood are good for putting your car on but not for little kids bike thingie; or car pedals either".
XXBULLETSXX
301
Kannapolis, NC
Jul 28, 2005
#16
  • Jul 28, 2005
  • #16
Enjoy!
Has anyone done this yet? I'm trying to find out how hard it was and if you had any additional comments that you think should be added to help the next guy?
Can you tell I'm at work and bored....thanks guys & gals!
Carnivore
154
Ferndale, WA
Jul 28, 2005
#17
  • Jul 28, 2005
  • #17
When I put in my new floorpans I made new seat mounts instead of using the old rusted ones. Also, my budy and I made brackets so I can move the seat an extra 6" back if need be... if its too far I can always use the on-seat rail sliders to move forward some... no short people can drive it though I'd bet.. =)
I havent tried it yet though as the car is still in progress.
XXBULLETSXX
301
Kannapolis, NC
Jul 28, 2005
#18
  • Jul 28, 2005
  • #18
Do you have any pictures of your custom slider?
Carnivore
154
Ferndale, WA
Jul 28, 2005
#19
  • Jul 28, 2005
  • #19
The slider isnt custom, I meant the slider on the seat.. The custom part is the rails onto which the seat bolts... The rails bolt into the stock position holes so if I want to, I dont need to even use them at all.... I'll see if I can find a picture to show you what I'm trying to say... cant now though, the're on my home comp if I even have the pics anymore... which reminds me, I need to find out where the crap I put those rails.. =)
Jester67
908
TN
Jul 28, 2005
#20
  • Jul 28, 2005
  • #20
Sorry not yet I had planned to do it during my 4th of July holiday but had house gests instead. And the 100 + temperatures are keeping me inside not in the car welding. But if all goes well it will have it soon I will post photos ASAP.
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
G
First Car Forum... EVER.
  • Godless
  • Sep 9, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 9, 2025
General karthief
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
