Lets play "Name the Part"
bigap15
115
As you know, i have been havin shifter troubles. Well i took the shifter off and found out that the little plastic bushing type piece that fits in the tranny where the shifter goes into is busted. I need a new one. Can someone please tell me what it is called and/or where i may be able to order it from. thanx in advance
FWIW, when I was at the dealer, that particular guy called it a shift rod cup, as I recall.
I gave up on describing it and had him pull up the Fische (sp?) and showed him what part it was.
ok i have another one. Do you know the disc brake anti-rattle spring that is in the front calipers. Where can i order one off the net. I couldnt find it on lrs.
