I offered to explain how the word "ratio" may be defined two different ways. Follow me. Here goes:
A ratio is an expression of the numerical relationship between two similar things. In the context of gearing and specifically differentials, ratio compares the rotational relationship between the axle and the and the pinion. Example: 3:1 means the pinion revolves three time for each revolution of the ring gear which drives the axle.
If the ratio were LOWERED to, say, 5:1, there would be a LOWER relationship between the two numbers. Conversely, a change to 2:1 would RAISE the relationship.
Confused?
Remember, I'm playing with words just like the President who said: "Ah didn't have sex with that woman."
I realize that this runs contary to popular thinking. Comments?
Confused?
Remember, I'm playing with words just like the President who said: "Ah didn't have sex with that woman."I realize that this runs contary to popular thinking. Comments?
That part there really got me thinking.
When someone says they have low gears, they mean they have a numerically high ratio. But why did they say they had low gears if the ratio is higher? I think this came from transmissions. 1st gear is "lower" then 2nd gear because 1 is lower then 2; even though the numerical ratio is higher for 1st then it is for 2nd. We are calling it a "lower" gear not because of its numerical ratio, but because of its location in the transmission. I think that this just stuck with people, and worked its way into society. Maybe I'm wrong/crazy, but I think that this is where it all started from.
