Lets Talk Dot Drag Tires
  • Thread starter Thread starter Chuckman
  • Start date Start date Jan 24, 2015
  • 3
  • 4
  • 5
First Prev 4 of 5 Next Last
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 28, 2015
#61
  • Jan 28, 2015
  • #61
nope not my bosses... i just work on it around the clock and make sure it is ready for the track. im guessing you just cant fit a 28" tire. and if thats the case id find a way to make it fit.
id honestly love to hear why turbo guys would rather have a 26" tire and what ever gearing they need vs the 28" tire and what ever gearing they need.
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Jan 28, 2015
#62
  • Jan 28, 2015
  • #62
Being that it's an SN95, I can EASILY fit a 28" tire under the car. However its completely unnecessary. If I ever decide to turn up the boost, a larger tire MIGHT be justified. However, relevant to THIS conversation, the OP would be ill served to attempt to run on a 28" tire. His combo just doesn't have enough to it, to over-power a 26" tire.
So, either keep your posts relevant, or kindly leave the thread.
Comparing a boosted 363 to a stockish N/A 302. Pfft...
srtthis
5,129
1,666
204
Maryland
Jan 28, 2015
#63
  • Jan 28, 2015
  • #63
haha whatever... you are the one who brought up turbo cars and said i dont know as much as i think i do.
i'll stick with the better tire and add gear for what i need.
if im not class limited im sticking the best tire under it i can get and i'll gear accordingly
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#64
  • Jan 28, 2015
  • #64
Sharad said:
You can make a radial work on a stick car, but it takes a lot more finesse than a slick. You'll have more throw away passes on a radial than on a slick, but the car may run quicker on the radial.
What is the best 60' ET and MPH you have seen with a radial on a stick car? Im not talking about the FS guys that will adjust clutch shim between rounds if needed, those are the only guys that ive seen make it work with a radial and that doesnt really apply to 98% of the guys trying to hook a radial with a clutch.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#65
  • Jan 28, 2015
  • #65
addermk2 said:
Apparently not as much as you think you do... especially when the entire turbo community recommends that I step down to something like a 3.27.
you could easily see if a gear ratio change would help the combination if you put a 28" tire on the car...
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Jan 28, 2015
#66
  • Jan 28, 2015
  • #66
I could, but I wont. Also didn't ask for advise.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#67
  • Jan 28, 2015
  • #67
Who pis.sed in your cheerios?
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Jan 28, 2015
#68
  • Jan 28, 2015
  • #68
Not an overwhelming fan of people trying to tell me how to build my car, or how to set it up. I didn't ask for help because I don't have an issue. I don't have the power to trap faster than what my car is geared for. It's a foot brake car, it's a street car... and its MY car.
So unless you want to pay to add parts that I don't need... I suggest you focus on the OP, not me.
hoopty5.0
mechanicus terribilis
7,848
6,992
214
SW Houston
Jan 28, 2015
#69
  • Jan 28, 2015
  • #69
Came for the info, stayed for the LOLZ.
I seriously think this guy has an ailment that makes him angry. Herp, hemorrhoids, dunno for sure, but holy crap.
Reactions: A5literMan
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#70
  • Jan 28, 2015
  • #70
buttherpies, its a new internet disease
Reactions: A5literMan, srtthis and hoopty5.0
hoopty5.0
7,848
6,992
214
SW Houston
Jan 28, 2015
#71
  • Jan 28, 2015
  • #71
Got awful quiet in here.
7upstang91
936
124
74
Florida
Jan 28, 2015
#72
  • Jan 28, 2015
  • #72
They must have gone to taco bell!
elarm1
1,428
652
154
N.Va
Jan 28, 2015
#73
  • Jan 28, 2015
  • #73
Wow this thread got outta hand pretty fast! What gives?
hoopty5.0
7,848
6,992
214
SW Houston
Jan 28, 2015
#74
  • Jan 28, 2015
  • #74
See post #s 69 & 70.
Reactions: elarm1
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#75
  • Jan 28, 2015
  • #75
It actually started around post #56, i wasnt aware that discussing different combinations was so frowned upon...
Chuckman said:
i believe both the et streets and qtps are stiff walls.
Not 100% sure about qtp's but the gen 1 ET street bias ply tires are most definitely not a stiff sidewall.
Chuckman said:
again, sizes im looking at:
275/50-15 (26x11.5): same o.d. as my street tires and my old nittos, shouldnt have fitment issues, but 4.10s make for a lot of revs
255/60-15 (27x10.5): a little more sidewall (and looks awesome in the well), but loses an inch in width, but also shouldnt have fit issues
275/60-15 (28x11.5): dunno if i have the power to really get this tire moving yet, possible fit issues, but is basically the standard "rule" size for almost every class i'd be interested in assuming i started class racing
What material is your clutch disc made from and do you know the base pressure? You should look into Mickey Thompsons new bias ply ET street R tire in either a 26 or 28" size, it has the DOT number and is designed to be driven on the street. This is a brand new tire and i think it will have much more sidewall stability than the old ET street. On a car without much adjustability i would go with the 28" tire unless you know for a fact you will be racing on a surface that is always prepped well.
http://www.mickeythompsontires.com/strip.php?item=ETStreetR
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 28, 2015
#76
  • Jan 28, 2015
  • #76
Popcorn anyone ?
elarm1
1,428
652
154
N.Va
Jan 28, 2015
#77
  • Jan 28, 2015
  • #77
@90lxcoupe So the P305/45R17 for my 10.5 Cobra wheels should be good for the street? Seems like the 28" tire would be too big?
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 28, 2015
#78
  • Jan 28, 2015
  • #78
Sorry to thread jack. Do you think a 28x11.5x15 fits with a 15x10 weld w/6.5" back spacing? Running TeamZ rear springs? I'm pretty sure I'm going to have to roll the fender and probably use the hammer?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 28, 2015
#79
  • Jan 28, 2015
  • #79
It should fit, looking at the dimensions MT's chart that tire is slightly smaller than a ET Drag 28x10.5 slick, which is what i have on my car, on a 10" 6.5 BS wheel, my inner fenders have had the sledgehammer treatment and the fenders are also rolled, the 28x10.5 is a tight fit but judging by the numbers on that link the bias ET street R should fit better.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 28, 2015
#80
  • Jan 28, 2015
  • #80
I would never gear up and run a 28" tire for the track. Just me personally, but in doing so, you now need to adjust your street tires to make up for the gear change. A 28" race tire looks good, but a 28" street wheel/tire set up, can't say I'd like the look.
My suggestion is keep it 27" tire or less.
  • 3
  • 4
  • 5
Tire size
  • Dr chaos1
  • Feb 26, 2019
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 26, 2019
Dr chaos1
Tire / Wheel Combo Opinion Please
  • JD1964
  • Oct 4, 2017
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2017
JD1964
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
Drag Tire??
  • A5literMan
  • Jan 20, 2014
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 20, 2014
cleanLX
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
