  • SN95 4.6L Mustang Tech
Lets Talk Water Temp. Sensor Mounting Locations!!!!!!
  • Thread starter Thread starter SRT Handz
  • Start date Start date Feb 3, 2008
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Feb 3, 2008
  • Feb 3, 2008
So i am installing my Auto Meter Electric water temp Gauge next week.... but i am still undecided on where to mount the damn sensor. I have been reading on every damn Forum on the different mounting locations. I really dont care where it needs to be mounted, i Just want the best Reading Possible.
So Guys, where do you guys think the best place to have the Water Temp sensor Mounted? Where do you Guys have Yours Mounted? I have read alot and narrowed it down to these locations.
1. Coolant Plug on Side of Block (Heard This Give Bad Readings Due to Heat)
2. Tap the Thermostat Housing
3. Auto Meter Heater Hose Tap
4. Autometer Radiator Tap
what do you guys suggest?
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Feb 3, 2008
  • Feb 3, 2008
I have mine mounted on the side of the block, it does read a little high, usually about 200 degrees but it is reliable in the sense that it is always off by the same amount. I figure the real temperature is about 195. I like the block location because it is the most aesthetically appealing, you cant even see it unless you really look for it.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 3, 2008
  • Feb 3, 2008
do you use the block drain for the sensor? thats a good spot for them.
jstreet0204
939
Winston Salem, NC
Feb 3, 2008
  • Feb 3, 2008
The block drain location doesn't give a bad reading it is just going to be higher than other locations unless you modify your colling system. If anything it is better to know the highest reading since that is the area that is usually going to fail first. The rear drivers side pistons.
RandyStinchcomb
1,159
Randallstown, Md
Feb 4, 2008
  • Feb 4, 2008
tap the thermostat housing..... fast, cheap and easy to-do
deftsound
Apr 6, 2004
945
Texas City TX
Feb 4, 2008
  • Feb 4, 2008
the block location is pretty easy too, takes 10 minutes to get the drain plug out and screw the temp sender in...the only hard part is getting your socket to reach up there
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Fan temp sensor location.
  • 7-UP BILL
  • Apr 3, 2026
Fox 5.0 Mustang Tech Apr 7, 2026
KRUISR
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
