Licoln Fan wires
rustang87
70
Sac
There are 3 wires.
2- Black
1- BLue
I have the DCC Fk35. It needs 2 connections, neggative and possitive.
I beleive that the blue is positive, i can see that at the bottom of the plug on the fan. But there are 2 blk's, how do I know that I am wiring the fan on HIgh?
Basicly.... How do I wire the 18" Lincoln Fan ( it says ford on the fan, I know they are the same.) on the high setting?
Oh yeah, what 12v source are you guys using for the ignition input?
Thanks!!!
Does M. Smith's article note which wires are which?
The ignition wire for the controller is for sensing only (to let the controller know when it's acceptable to run the fan). Something like the key-on wire to the coolant overflow bottle should work fine.
Good luck.
I guess I don't count. :shrug:
I thought it was a valid question. I wouldn't do a Mark 8 fan install without lookin at Monte's great article.
Now that I think about it, Srothfuss installed the same components and wrote a nice thread about it. See his article too.
Good luck.
Your car should have had an overflow sensor in OEM form. Whether or not you still use the sensor, the wiring to it should still be present. Just about any 12 volt key-on hot wire under the hood should work. That said, I steer clear of things like the ignition coil. I'd use something close to where you mount your controller.
the instructions are at home, I think it said avoid the " negative side" of the coil.
I don't think the 87 lx had the coolant sensor... It is a very early 87...
Any other examples?
Man, I need internet at home... This is harder at work...
Thanks guys!
Look a little closer at those 2 black wires, one of them should be solid black and one should be black with a thin orange stripe. If you still see no stripe just follow the wires down the pigtail to the plug and the where the plug goes into the fan motor it should be marked with a - and +.
Normally the black is ground, black/orange is high, and the blue is low. With a DCC it does not matter wether you use the high speed wire or the low speed wire
Thanks guys!
You are correct - the negative side of the coil is NOT a power ground pathway (just like you dont use the ground path on fuel injectors).
Good luck.
