Lifter Check
  • Thread starter Thread starter Butterfinger
  • Start date Start date Feb 12, 2011
Butterfinger
74
Washington
Feb 12, 2011
  • Feb 12, 2011
I read that when checking the piston-to-valve clearance to make sure the hydraulic lifters do not collapse, what does that mean?
Butterfinger
74
Washington
Feb 12, 2011
  • Feb 12, 2011
I think I figured it out (sometimes search does yield some results), if the lifter collapses, then the piston is pushing the valve causing the lifter to collapse (obviously not enough clearance). Is this correct?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Feb 13, 2011
  • Feb 13, 2011
Hydraulic lifters use oil to "pump up" during operation, hence the "hydraulic" part of the name. If the engine is not running, the plunger in the lifter will push further down inside, which will create less valve lift when checking your clearance; therefore, making it look like you have more clearance than you actually do.
Take the retaining clip out of the top of the lifter. There will be three pieces held inside, one of the three pieces is a spring, so make sure you don't let it fly out. Take the top part out, then you will find the second part is the plunger, followed by the spring. Leave the spring out, turn the plunger upside down and place back inside the lifter, then replace the top part of the lifter. You can leave the retainer clip out. You have now made the lifter solid and you can use it to check your clearance when turning the motor over by hand.
After your done, reassemble lifter like before and reinstall retaining clip.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 14, 2011
  • Feb 14, 2011
If you happen to have an old lifter, you could do this and leave it that way permanently. No risk of harm to a brand new one then.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Old/new guy
  • mustangtoby
  • Aug 17, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
K
collapsed or stuck "lifter" ?
  • kingcoy
  • Oct 23, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 23, 2025
nickyb
